Enable monitoring
Hint: Use Juju 3. Otherwise replace
juju run ...
withjuju run-action --wait ...
andjuju integrate
withjuju relate
for Juju 2.9.
Enable monitoring requires that you:
Switch to COS K8s environment and offer COS interfaces to be cross-model integrated (related) with Charmed MySQL VM model:
# Switch to Kubernetes controller, for the cos model.
juju switch <k8s_controller>:<cos_model_name>
juju offer grafana:grafana-dashboard
juju offer loki:logging
juju offer prometheus:receive-remote-write
Switch to Charmed MySQL VM model, find offers and integrate (relate) with them:
# We are on the Kubernetes controller, for the cos model. Switch to mysql model
juju switch <machine_controller_name>:<mysql_model_name>
juju find-offers <k8s_controller>: # Do not miss ':' here!
A similar output should appear, if k8s
is the k8s controller name and cos
the model where cos-lite
has been deployed:
Store URL Access Interfaces
k8s admin/cos.grafana admin grafana:grafana-dashboard
k8s admin/cos.loki admin loki:logging
k8s admin/cos.prometheus admin prometheus:receive-remote-write
Consume offers to be reachable in the current model:
juju consume k8s:admin/cos.grafana
juju consume k8s:admin/cos.loki
juju consume k8s:admin/cos.prometheus
Now, deploy ‘grafana-agent’ (subordinate charm) and integrate (relate) it with Charmed MySQL, later integrate (relate) grafana-agent
with consumed COS offers:
juju deploy grafana-agent
juju integrate grafana-agent mysql:cos-agent
juju integrate grafana-agent grafana
juju integrate grafana-agent loki
juju integrate grafana-agent prometheus
After this is complete, Grafana will show the new dashboards: MySQL Exporter
and allows access for Charmed MySQL logs on Loki.
The example of juju status
on Charmed MySQL VM model:
ubuntu@localhost:~$ juju status
vmmodel local localhost/localhost 3.1.6 unsupported 00:12:18+02:00
SAAS Status Store URL
grafana active k8s admin/cos.grafana
loki active k8s admin/cos.loki
prometheus active k8s admin/cos.prometheus
grafana-agent active 1 grafana-agent edge 5 no
mysql 8.0.32 active 1 mysql 8.0/edge 144 no Primary
mysql/3* active idle 4 10.85.186.140 3306/tcp,33060/tcp Primary
grafana-agent/0* active idle 10.85.186.140
4 started 10.85.186.140 juju-fcde9e-4 jammy Running
on COS K8s model:
cos k8s microk8s/localhost 3.1.6 unsupported 00:15:31+02:00
alertmanager 0.23.0 active 1 alertmanager-k8s stable 47 10.152.183.206 no
catalogue active 1 catalogue-k8s stable 13 10.152.183.183 no
grafana 9.2.1 active 1 grafana-k8s stable 64 10.152.183.140 no
loki 2.4.1 active 1 loki-k8s stable 60 10.152.183.241 no
prometheus 2.33.5 active 1 prometheus-k8s stable 103 10.152.183.240 no
traefik 2.9.6 active 1 traefik-k8s stable 110 10.76.203.178 no
alertmanager/0* active idle 10.1.84.125
catalogue/0* active idle 10.1.84.127
grafana/0* active idle 10.1.84.83
loki/0* active idle 10.1.84.79
prometheus/0* active idle 10.1.84.96
traefik/0* active idle 10.1.84.119
Offer Application Charm Rev Connected Endpoint Interface Role
grafana grafana grafana-k8s 64 1/1 grafana-dashboard grafana_dashboard requirer
loki loki loki-k8s 60 1/1 logging loki_push_api provider
prometheus prometheus prometheus-k8s 103 1/1 receive-remote-write prometheus_remote_write provider
To connect Grafana WEB interface, follow the COS section “Browse dashboards”:
juju run grafana/leader get-admin-password --model <k8s_controller>:<cos_model_name>
