How to deploy using Terraform
Terraform is an infrastructure automation tool to provision and manage resources in clouds or data centers. To deploy Charmed MySQL using Terraform and Juju, you can use the Juju Terraform Provider.
The easiest way is to start from these examples of terraform modules prepared by Canonical. This page will guide you through a deployment using an example module for MySQL on machines.
For an in-depth introduction to the Juju Terraform Provider, read this Discourse post.
Note: Storage support was added in Juju Terraform Provider version 0.13+.
- Install Terraform tooling
- Verify the deployment
- Apply the deployment
- Check deployment status
- Clean up
This guide assumes Juju is installed and you have an LXD controller already bootstrapped. For more information, check the Set up the environment tutorial page.
Let’s install Terraform Provider and example modules:
sudo snap install terraform --classic
Switch to the LXD provider and create a new model:
juju switch lxd
juju add-model my-model
Clone examples and navigate to the MySQL machine module:
git clone https://github.com/canonical/terraform-modules.git
cd terraform-modules/modules/machine/mysql
Initialise the Juju Terraform Provider:
terraform init
Open the main.tf file to see the brief contents of the Terraform module:
resource "juju_application" "machine_mysql" {
name = var.mysql_application_name
model = var.juju_model_name
trust = true
charm {
name = "mysql"
channel = var.mysql_charm_channel
units = 1
Run terraform plan to get a preview of the changes that will be made:
terraform plan -var "juju_model_name=my-model"
If everything looks correct, deploy the resources (skip the approval):
terraform apply -auto-approve -var "juju_model_name=my-model"
Check the deployment status with
juju status --model lxd:my-model --watch 1s
Sample output:
my-model lxd-controller localhost/localhost 3.5.3 unsupported 12:49:34Z
mysql 8.0.36-0ubun... active 1 mysql 8.0/stable 240 no
mysql/0* active idle 0 10.101.248.225 3306,33060/tcp Primary
0 started 10.101.248.225 juju-c4a403-0 ubuntu@22.04 Running
Continue to operate the charm as usual from here or apply further Terraform changes.
Clean up
To keep the house clean, remove the newly deployed Charmed PostgreSQL by running
terraform destroy -var "juju_model_name=my-model"
Sample output:
juju_application.machine_mysql: Refreshing state... [id=my-model:mysql]
Terraform used the selected providers to generate the following execution plan. Resource actions are indicated with the following symbols:
- destroy
Terraform will perform the following actions:
# juju_application.machine_mysql will be destroyed
- resource "juju_application" "machine_mysql" {
- constraints = "arch=amd64" -> null
- id = "my-model:mysql" -> null
- model = "my-model" -> null
- name = "mysql" -> null
- placement = "0" -> null
- storage = [
- count = 1 -> null
- label = "database" -> null
- pool = "rootfs" -> null
- size = "99G" -> null
] -> null
- trust = true -> null
- units = 1 -> null
- charm {
- base = "ubuntu@22.04" -> null
- channel = "8.0/stable" -> null
- revision = 240 -> null
- series = "jammy" -> null
Plan: 0 to add, 0 to change, 1 to destroy.
Changes to Outputs:
- application_name = "mysql" -> null
Do you really want to destroy all resources?
Terraform will destroy all your managed infrastructure, as shown above.
There is no undo. Only 'yes' will be accepted to confirm.
Enter a value: yes
juju_application.machine_mysql: Destroying... [id=my-model:mysql]
juju_application.machine_mysql: Destruction complete after 0s
Destroy complete! Resources: 1 destroyed.
For more examples of Terraform modules for VM, see the other directories in the terraform-modules repository.
Feel free to contact us if you have any question and collaborate with us on GitHub!
