How to deploy on AWS EC2
Amazon Web Services is a popular subsidiary of Amazon that provides on-demand cloud computing platforms on a metered pay-as-you-go basis. Access the AWS web console at console.aws.amazon.com.
- Install AWS and Juju tooling
- Bootstrap Juju controller on AWS EC2
- Deploy charms
- Expose database (optional)
- Clean up
Install Juju via snap:
sudo snap install juju
Follow the installation guides for:
- AWs CLI - the Amazon Web Services CLI
To check they are all correctly installed, you can run the commands demonstrated below with sample outputs:
~$ juju version
3.5.4-genericlinux-amd64
~$ aws --version
aws-cli/2.13.25 Python/3.11.5 Linux/6.2.0-33-generic exe/x86_64.ubuntu.23 prompt/off
Authenticate
Create an IAM account (or use legacy access keys) to operate AWS EC2:
mkdir -p ~/.aws && cat <<- EOF > ~/.aws/credentials.yaml
credentials:
aws:
NAME_OF_YOUR_CREDENTIAL:
auth-type: access-key
access-key: SECRET_ACCESS_KEY_ID
secret-key: SECRET_ACCESS_KEY_VALUE
EOF
Add AWS credentials to Juju:
juju add-credential aws -f ~/.aws/credentials.yaml
Bootstrap Juju controller (check all supported configuration options):
juju bootstrap aws
Output example
> juju bootstrap aws
Creating Juju controller "aws-us-east-1" on aws/us-east-1
Looking for packaged Juju agent version 3.5.4 for amd64
Located Juju agent version 3.5.4-ubuntu-amd64 at https://juju-dist-aws.s3.amazonaws.com/agents/agent/3.5.4/juju-3.5.4-linux-amd64.tgz
Launching controller instance(s) on aws/us-east-1...
- i-0f4615983d113166d (arch=amd64 mem=8G cores=2)
Installing Juju agent on bootstrap instance
Waiting for address
Attempting to connect to 54.226.221.6:22
Attempting to connect to 172.31.20.34:22
Connected to 54.226.221.6
Running machine configuration script...
Bootstrap agent now started
Contacting Juju controller at 54.226.221.6 to verify accessibility...
Bootstrap complete, controller "aws-us-east-1" is now available
Controller machines are in the "controller" model
Now you can run
juju add-model <model-name>
to create a new model to deploy workloads.
You can check the AWS EC2 instance availability (ensure the right AWS region chosen!):
Create a new Juju model:
juju add-model welcome
(Optional) Increase the debug level if you are troubleshooting charms:
juju model-config logging-config='<root>=INFO;unit=DEBUG'
Deploy charms
The following command deploys MySQL and Data-Integrator (the charm to request a test DB):
juju deploy mysql
juju deploy data-integrator --config database-name=test123
juju relate mysql data-integrator
Check the status:
> juju status --relations
welcome aws-us-east-1 aws/us-east-1 3.5.4 unsupported 17:52:25+02:00
data-integrator active 1 data-integrator latest/stable 41 no
mysql 8.0.36-0ubun... active 3 mysql 8.0/stable 240 no
data-integrator/1* active idle 9 34.207.85.249
mysql/0* active idle 6 107.21.70.243 3306,33060/tcp Primary
mysql/1 active idle 7 3.82.62.144 3306,33060/tcp
mysql/2 active idle 8 44.193.79.253 3306,33060/tcp
6 started 107.21.70.243 i-0db4d16715a59f74d ubuntu@22.04 us-east-1a running
7 started 3.82.62.144 i-038a7ca89b40f83bf ubuntu@22.04 us-east-1b running
8 started 44.193.79.253 i-01dc0ad71d5607fdb ubuntu@22.04 us-east-1c running
9 started 34.207.85.249 i-068d4d0d8b7ede754 ubuntu@22.04 us-east-1d running
data-integrator:data-integrator-peers data-integrator:data-integrator-peers data-integrator-peers peer
mysql:database data-integrator:mysql mysql_client regular
mysql:database-peers mysql:database-peers mysql_peers peer
mysql:restart mysql:restart rolling_op peer
mysql:upgrade mysql:upgrade upgrade peer
Once deployed, request the credentials for your newly bootstrapped MySQL database.
For Juju 2.9 use:
juju run-action --wait data-integrator/leader get-credentials
and for newer Juju 3+ use:
The output example:
mysql:
data: '{"database": "test123", "external-node-connectivity": "true", "requested-secrets":
"[\"username\", \"password\", \"tls\", \"tls-ca\", \"uris\"]"}'
database: test123
endpoints: 172.31.16.250:3306
password: e7vOMyzj2FnrBDnXZdXScEOc
read-only-endpoints: 172.31.10.167:3306,172.31.39.202:3306
username: relation-16
version: 8.0.36-0ubuntu0.22.04.1
ok: "True"
At this point, you can access your DB inside AWS using the internal IP address. All further Juju applications will use the database through the internal network:
> mysql -h 172.31.16.250 -P 3306 -u relation-16 -pe7vOMyzj2FnrBDnXZdXScEOc test123
mysql> show databases;
| Database |
| information_schema |
| performance_schema |
| test123 |
3 rows in set (0.00 sec)
From here you can use/scale/backup/restore/refresh your newly deployed Charmed MySQL.
If necessary to access DB from outside of AWS (warning: opening ports to public is risky) open the AWS firewall using the simple juju expose functionality:
juju expose mysql
Once exposed, you can connect your database using the same credentials as above (Important: this time use the EC2 Public IP assigned to the MySQL instance):
> juju status mysql
> mysql -h 107.21.70.243 -P 3306 -u relation-16 -pe7vOMyzj2FnrBDnXZdXScEOc test123
| Database |
| test123 |
3 rows in set (0.13 sec)
To close the public access run:
juju unexpose mysql
Clean up
Always clean AWS resources that are no longer necessary - they could be costly!
To destroy the Juju controller and remove AWS instance (warning: all your data will be permanently removed):
> juju controllers
Controller Model User Access Cloud/Region Models Nodes HA Version
aws-us-east-1* - admin superuser aws/us-east-1 1 1 none 3.5.4
> juju destroy-controller aws-us-east-1 --destroy-all-models --destroy-storage --force
Next, check and manually delete all unnecessary AWS EC2 instances, to show the list of all your EC2 instances run the following command (make sure the correct region used!):
aws ec2 describe-instances --region us-east-1 --query "Reservations[].Instances[*].{InstanceType: InstanceType, InstanceId: InstanceId, State: State.Name}" --output table
Output example
| DescribeInstances |
| InstanceId | InstanceType | State |
| i-0f374435695ffc54c| m7i.large | terminated |
| i-0e1e8279f6b2a08e0| m7i.large | terminated |
| i-061e0d10d36c8cffe| m7i.large | terminated |
| i-0f4615983d113166d| m7i.large | terminated |
List your Juju credentials:
> juju credentials
Client Credentials:
Cloud Credentials
aws NAME_OF_YOUR_CREDENTIAL
Remove AWS EC2 CLI credentials from Juju:
> juju remove-credential aws NAME_OF_YOUR_CREDENTIAL
Finally, remove AWS CLI user credentials (to avoid forgetting and leaking):
rm -f ~/.aws/credentials.yaml
