IMPORTANT: it is NO longer topical article. Please follow the modern one!
This document is for the historical reference only and MUST NOT be used for deployments!
Configuring asynchronous replication: MySQL InnoDB ClusterSet
WARNING: it is an internal article. Do NOT use it in production! Contact Canonical Data Platform team if you are interested in the topic.
Intro
Read more about MySQL InnoDB ClusterSet and watch the presentation.
For simplicity, we deploy both MySQL InnoDB Clusters into the same model, but the proper design is to install them in different Regions/Clouds:
Bootstrap
Bootstrap two MySQL InnoDB Clusters (Rome and Lisbon) and test application to generate SQL traffic:
juju deploy --constraints mem=2G mysql mysql-1st --channel 8.0/edge -n 3 --config cluster-name=ROME
juju deploy --constraints mem=2G mysql mysql-2nd --channel 8.0/edge -n 3 --config cluster-name=LISBON
juju deploy mysql-test-app --channel edge
juju relate mysql-1st mysql-test-app:database
juju wait-for application mysql-1st --query='status=="active"' && juju wait-for application mysql-2nd --query='status=="active"'
Collect clusters details
Collect both clusters credentials to reuse later:
cluster_name_1st=$(juju show-unit mysql-1st/0 | yq '.. | select(. | has("cluster-name")).cluster-name')
cluster_name_2nd=$(juju show-unit mysql-2nd/0 | yq '.. | select(. | has("cluster-name")).cluster-name')
root_password_1st=$(juju run mysql-1st/0 get-password username=root | yq '.. | select(. | has("password")).password')
root_password_2nd=$(juju run mysql-2nd/0 get-password username=root | yq '.. | select(. | has("password")).password')
serverconfig_password_1st=$(juju run mysql-1st/0 get-password username=serverconfig | yq '.. | select(. | has("password")).password')
serverconfig_password_2nd=$(juju run mysql-2nd/0 get-password username=serverconfig | yq '.. | select(. | has("password")).password')
clusteradmin_password_1st=$(juju run mysql-1st/0 get-password username=clusteradmin | yq '.. | select(. | has("password")).password')
clusteradmin_password_2nd=$(juju run mysql-2nd/0 get-password username=clusteradmin | yq '.. | select(. | has("password")).password')
monitoring_password_1st=$(juju run mysql-1st/0 get-password username=monitoring | yq '.. | select(. | has("password")).password')
monitoring_password_2nd=$(juju run mysql-2nd/0 get-password username=monitoring | yq '.. | select(. | has("password")).password')
backups_password_1st=$(juju run mysql-1st/0 get-password username=backups | yq '.. | select(. | has("password")).password')
backups_password_2nd=$(juju run mysql-2nd/0 get-password username=backups | yq '.. | select(. | has("password")).password')
cat << EOF
Cluster names:
1st: ${cluster_name_1st}
2nd: ${cluster_name_2nd}
Credentials:
1st: root:${root_password_1st}
2nd: root:${root_password_2nd}
1st: serverconfig:${serverconfig_password_1st}
2nd: serverconfig:${serverconfig_password_2nd}
1st: clusteradmin:${clusteradmin_password_1st}
2nd: clusteradmin:${clusteradmin_password_2nd}
EOF
Sync credentials
It is important to set the first cluster credentials on the second cluster to allow charm operator to continue managing 2nd Cluster after joining the ClusterSet:
juju run mysql-2nd/leader set-password username=root password=${root_password_1st} # not really necessary.
juju run mysql-2nd/leader set-password username=clusteradmin password=${clusteradmin_password_1st}
juju run mysql-2nd/leader set-password username=serverconfig password=${serverconfig_password_1st}
juju run mysql-2nd/leader set-password username=monitoring password=${monitoring_password_1st}
juju run mysql-2nd/leader set-password username=backups password=${backups_password_1st}
Pause operators
To avoid any damage by the operator, we should pause all activities there, until re-configuration is finished. WIP: DPE-2183, DPE-2184.
TODO: pause all MySQL Clusters (in ClusterSet) and all mysql-routers (as Juju update-status might trigger cluster.rescan() and produce troubles for Cluster members are being synced via mysql-shell).
Destroy the 2nd Cluster (to be re-created inside the ClusterSet)
It is NOT possible to “merge” two different MySQL InnoDB Clusters due to different GTID on both Clusters. We are going to dissolve the second Cluster to re-create it as a clone of the first one:
juju ssh mysql-2nd/leader charmed-mysql.mysqlsh --py -h127.0.0.1 -uclusteradmin -p${clusteradmin_password_1st}
> dba.get_cluster().dissolve(); # answer YES to all questions, remember IPs of all cluster members
Re-create the 2nd Cluster as 1st Cluster clone
Create the second cluster as a clone copy of the first cluster under the first ClusterSet.
IMPORTANT: replace all FIXME_ labels with a proper values (unit IPs and cluster-name)!
juju ssh mysql-1st/leader charmed-mysql.mysqlsh --py -h127.0.0.1 -uclusteradmin -p${clusteradmin_password_1st}
> cs = dba.get_cluster_set()
> cluster2 = cs.create_replica_cluster("clusteradmin@FIXME_IP_1:3306", "FIXME_LISBON", recoveryProgress=1, timeout=10, recoveryMethod='clone');
> cluster2.set_instance_option('clusteradmin@FIXME_IP_1:3306', 'label', 'mysql-2nd-0');
> cluster2.add_instance('clusteradmin@FIXME_IP_2:3306', label="mysql-2nd-1", recoveryMethod='clone');
> cluster2.add_instance('clusteradmin@FIXME_IP_3:3306', label="mysql-2nd-2", recoveryMethod='clone');
Check the status
Check the Juju and MySQL InnoDB Cluster(Set) statuses:
juju status
clusterset lxd localhost/localhost 2.9.43 unsupported 15:27:08+02:00
mysql-1st 8.0.32-0ubun... active 3 mysql 8.0/edge 164 no
mysql-2nd 8.0.32-0ubun... active 3 mysql 8.0/edge 164 no
mysql-test-app 0.0.2 active 1 mysql-test-app edge 20 no
mysql-1st/0 active idle 0 10.18.215.9 3306/tcp,33060/tcp
mysql-1st/1 active idle 1 10.18.215.81 3306/tcp,33060/tcp
mysql-1st/2* active idle 2 10.18.215.67 3306/tcp,33060/tcp Primary
mysql-2nd/0 active idle 3 10.18.215.21 3306/tcp,33060/tcp
mysql-2nd/1 active idle 4 10.18.215.87 3306/tcp,33060/tcp
mysql-2nd/2* active idle 5 10.18.215.60 3306/tcp,33060/tcp Primary
mysql-test-app/0* active idle 6 10.18.215.174
0 started 10.18.215.9 juju-014b8f-0 jammy Running
1 started 10.18.215.81 juju-014b8f-1 jammy Running
2 started 10.18.215.67 juju-014b8f-2 jammy Running
3 started 10.18.215.21 juju-014b8f-3 jammy Running
4 started 10.18.215.87 juju-014b8f-4 jammy Running
5 started 10.18.215.60 juju-014b8f-5 jammy Running
6 started 10.18.215.174 juju-014b8f-6 jammy Running
MySQL InnoDB ClusterSet status:
> dba.get_cluster_set().status(extended=1);
"clusters": {
"LISBON": {
"clusterRole": "REPLICA",
"clusterSetReplication": {
"applierStatus": "APPLIED_ALL",
"applierThreadState": "Waiting for an event from Coordinator",
"applierWorkerThreads": 4,
"receiver": "10.18.215.60:3306",
"receiverStatus": "ON",
"receiverThreadState": "Waiting for source to send event",
"source": "10.18.215.67:3306"
"clusterSetReplicationStatus": "OK",
"globalStatus": "OK",
"status": "OK",
"statusText": "Cluster is ONLINE and can tolerate up to ONE failure.",
"topology": {
"mysql-2nd-0": {
"address": "10.18.215.60:3306",
"memberRole": "PRIMARY",
"mode": "R/O",
"replicationLagFromImmediateSource": "",
"replicationLagFromOriginalSource": "",
"status": "ONLINE",
"version": "8.0.32"
"mysql-2nd-1": {
"address": "10.18.215.21:3306",
"memberRole": "SECONDARY",
"mode": "R/O",
"status": "ONLINE",
"version": "8.0.32"
"mysql-2nd-2": {
"address": "10.18.215.87:3306",
"mode": "R/O",
"status": "ONLINE",
"version": "8.0.32"
"transactionSet": "0a2d1861-0ea1-11ee-8ec2-00163ef59470:1-17047,0a2d1b28-0ea1-11ee-8ec2-00163ef59470:1-5,1549f330-0ea2-11ee-95a9-00163e5d863b:1-7,ec27d3f3-0ea0-11ee-aa9d-00163ef59470:1-4",
"transactionSetConsistencyStatus": "OK",
"transactionSetErrantGtidSet": "",
"transactionSetMissingGtidSet": ""
"ROME": {
"clusterRole": "PRIMARY",
"primary": "10.18.215.67:3306",
"status": "OK",
"topology": {
"mysql-1st-0": {
"address": "10.18.215.9:3306",
"mode": "R/O",
"status": "ONLINE",
"version": "8.0.32"
"mysql-1st-1": {
"address": "10.18.215.81:3306",
"mode": "R/O",
"status": "ONLINE",
"version": "8.0.32"
"mysql-1st-2": {
"address": "10.18.215.67:3306",
"mode": "R/W",
"status": "ONLINE",
"version": "8.0.32"
"transactionSet": "0a2d1861-0ea1-11ee-8ec2-00163ef59470:1-17047,0a2d1b28-0ea1-11ee-8ec2-00163ef59470:1-5,1549f330-0ea2-11ee-95a9-00163e5d863b:1-6,ec27d3f3-0ea0-11ee-aa9d-00163ef59470:1-4"
"domainName": "cluster-set-0a16c7e0e4d4a8c8956911b8cadb17f3",
"globalPrimaryInstance": "10.18.215.67:3306",
"metadataServer": "10.18.215.67:3306",
"primaryCluster": "ROME",
"status": "HEALTHY",
"statusText": "All Clusters available."
MySQL 127.0.0.1:33060+ ssl Py >
All OK here!
MySQL Router
Removing test application to bootstrap two independent test applications behind mysql-router to provide the complete setup as displayed on the diagram above:
juju remove-application mysql-test-app
Bootstrap mysql-router with two independent test applications (note: series must match due to subordinate nature of mysql-router):
juju deploy mysql-test-app application-1st --channel edge --series jammy
juju deploy mysql-test-app application-2nd --channel edge --series jammy
juju deploy mysql-router mysql-router-1st --channel dpe/edge --series jammy
juju deploy mysql-router mysql-router-2nd --channel dpe/edge --series jammy
juju relate application-1st mysql-router-1st
juju relate mysql-router-1st mysql-1st # relate to primary ClusterSet first, otherwise cannot bootstrap!
juju relate mysql-router-1st mysql-2nd
juju relate application-2nd mysql-router-2nd
juju relate mysql-router-2nd mysql-1st # relate to primary ClusterSet first, otherwise cannot bootstrap!
juju relate mysql-router-2nd mysql-2nd
MySQL InnoDB ClusterSet configured MySQL Router automatically and test applications start using database:
> dba.get_cluster_set().list_routers()
"routers": {
"juju-014b8f-10.lxd::application-2nd": {
"hostname": "juju-014b8f-10.lxd",
"lastCheckIn": "2023-06-19 15:06:45",
"roPort": "3307",
"roXPort": "3309",
"rwPort": "3306",
"rwXPort": "3308",
"targetCluster": null,
"version": "8.0.32"
"juju-014b8f-9.lxd::application-1st": {
"hostname": "juju-014b8f-9.lxd",
"lastCheckIn": "2023-06-19 14:58:35",
"roPort": "3307",
"roXPort": "3309",
"rwPort": "3306",
"rwXPort": "3308",
"version": "8.0.32"
Juju status shows all the necessary relation and happy:
> juju status --relations
clusterset lxd localhost/localhost 2.9.43 unsupported 17:25:07+02:00
application-1st 0.0.2 active 1 mysql-test-app edge 20 no
application-2nd 0.0.2 waiting 1 mysql-test-app edge 20 no
mysql-router-1st active 1 mysql-router dpe/edge 77 no
mysql-router-2nd active 1 mysql-router dpe/edge 77 no
application-1st/0* active idle 9 10.18.215.211
mysql-router-1st/0* active idle 10.18.215.211 6446/tcp,6447/tcp,6448/tcp,6449/tcp
application-2nd/1* waiting idle 11 10.18.215.157
mysql-router-2nd/1* active idle 10.18.215.157 6446/tcp,6447/tcp,6448/tcp,6449/tcp
mysql-1st/3 active idle 8 10.18.215.86 3306/tcp,33060/tcp
8 started 10.18.215.86 juju-014b8f-8 jammy Running
9 started 10.18.215.211 juju-014b8f-9 jammy Running
11 started 10.18.215.157 juju-014b8f-11 jammy Running
application-1st:application-peers application-1st:application-peers application-peers peer
application-2nd:application-peers application-2nd:application-peers application-peers peer
mysql-1st:database mysql-router-1st:backend-database mysql_client regular
mysql-1st:database mysql-router-2nd:backend-database mysql_client regular
mysql-1st:database-peers mysql-1st:database-peers mysql_peers peer
mysql-2nd:database mysql-router-1st:backend-database mysql_client regular
mysql-2nd:database mysql-router-2nd:backend-database mysql_client regular
mysql-2nd:database-peers mysql-2nd:database-peers mysql_peers peer
mysql-router-1st:database application-1st:database mysql_client subordinate
mysql-router-1st:mysql-router-peers mysql-router-1st:mysql-router-peers mysql_router_peers peer
mysql-router-2nd:database application-2nd:database mysql_client subordinate
mysql-router-2nd:mysql-router-peers mysql-router-2nd:mysql-router-peers mysql_router_peers peer
ClusterSet/Cluster Scaling
to be continued…
ClusterSet/Cluster Switchovers
Read the general ClusterSet Emergency Failover. Juju, to be continued…
