Charmed MongoDB Tutorials > Deploy a sharded cluster > 2. Deploy MongoDB
Deploy MongoDB
Sharding is MongoDB’s solution to horizontal scaling. MongoDB’s documentation describes horizontal scaling in databases as the process of “ dividing a large database into smaller, more manageable pieces (called shards) and then distributing the shards across multiple machines.”
In Charmed MongoDB, we create sharded clusters by deploying several applications of Charmed MongoDB as individual cluster components, and then integrating them. This part of the tutorial will guide you through a practical example of a sharded cluster deployment.
- Deploy cluster components, i.e. shards and a config server
- Integrate shards with the config server
The first step to creating your sharded cluster is to deploy cluster components.
If you run juju deploy mongodb without specifying a role, the application will be automatically deployed as a replica set. To deploy a sharded cluster, we must manually define the roles of the individual cluster components:
juju deploy mongodb --config role="config-server" config-server
juju deploy mongodb --config role="shard" shard0
juju deploy mongodb --config role="shard" shard1
For a deeper explanation about the difference between replication and sharding see Explanation | Replication vs. sharded cluster deployments.
Use juju status --watch 1s to wait until these components are ready.
When the components are ready, your output should look similar to the example below:
Model           Controller  Cloud/Region         Version  SLA          Timestamp
sharding-model  overlord    localhost/localhost  3.1.7    unsupported  19:06:51+01:00
App            Version  Status   Scale  Charm    Channel    Rev  Exposed  Message
config-server           blocked      1  mongodb  6/stable   158  no       Missing relation to shard(s).
shard0                  blocked      1  mongodb  6/stable   158  no       Missing relation to config-server.
shard1                  blocked      1  mongodb  6/stable   158  no       Missing relation to config-server.
Unit              Workload  Agent  Machine  Public address  Ports            Message
config-server/0*  blocked   idle   0        10.56.148.138    27017-27018/tcp  Missing relation to shard(s).
shard0/0*         blocked   idle   1        10.56.148.149    27017/tcp        Missing relation to config-server.
shard1/0*         blocked   idle   2        10.56.148.60     27017/tcp        Missing relation to config-server.
Machine  State    Address       Inst id        Base          AZ  Message
0        started  10.125.59.63  juju-573669-0  ubuntu@22.04      Running
1        started  10.125.59.57  juju-573669-1  ubuntu@22.04      Running
2        started  10.125.59.90  juju-573669-2  ubuntu@22.04      Running
All statuses are blocked because the shards are not yet integrated/related with the config-server.
Juju integrations are a way to connect applications such that they can communicate with one another through compatible endpoints.To integrate the shards with the config server, run
juju integrate config-server:config-server shard0:sharding
juju integrate config-server:config-server shard1:sharding
 You’ll know your cluster is active and ready when juju status --watch 1s shows all apps as active.
sharding-model  overlord    localhost/localhost  3.1.7    unsupported  19:15:36+01:00
config-server           active      1  mongodb  6/beta   149  no       Primary
shard0                  active      1  mongodb  6/beta   149  no       Primary
shard1                  active      1  mongodb  6/beta   149  no       Primary
config-server/0*  active    idle   0        10.56.148.138    27017-27018/tcp  Primary
shard0/0*         active    idle   1        10.56.148.149    27017/tcp        Primary
shard1/0*         active    idle   2        10.56.148.60    27017/tcp        Primary
Next step: 3. Access a sharded cluster
