Charmed MongoDB Reference
Reference
The Reference section of our documentation contains pages for technical specifications, APIs, release notes, and other reference material for fast lookup.
In the sidebar navigation, you will find the following references:
Page Description
System requirements Software and hardware requirements for this charm
Release Notes Release notes for major revisions of this charm
Charm testing Overview of relevant software tests for this charm
In the tabs at the top of the page, you can find the following automatically generated API references:
Page Description
Integrations Integration/relation interfaces supported by this charm
Libraries Classes and interfaces used in charm code
Actions Juju actions supported by this charm
