How to manage passwords
Internal operator user
The operator user is used internally by the Charmed MongoDB Operator, the set-password action can be used to rotate its password.
- To set a specific password for the operator user
juju run mongodb-k8s/leader set-password password=<password>
where is the password you want to set
- To randomly generate a password for the operator user
Rotate application passwords
To rotate the passwords of users created for related applications, the relation should be removed and related again. That process will generate a new user and password for the application.
juju remove-relation <application> mongodb-k8s
juju add-relation <application> mongodb-k8s
where is the name of your application
