Creating and listing backups requires that you:
- Have a replica set with at least three-nodes deployed
- Access to S3 storage
- Have configured settings for S3 storage
Once you have a three-node replicaset that has configurations set for S3 storage, check that Charmed MongoDB is active and idle with juju status. Once Charmed MongoDB is active and idle, you can create your first backup with the create-backup command:
juju run mongodb-k8s/leader create-backup
You can list your available, failed, and in progress backups by running the list-backups command:
juju run mongodb-k8s/leader list-backups
