Charmed MongoDB How-to | Enable LDAP
How to enable LDAP authentication
LDAP (Lightweight Directory Access Protocol) enables centralized authentication for MongoDB Replica Sets and Sharded Clusters, reducing the overhead of managing local credentials and access policies.
This guide goes over the steps to integrate LDAP as an authentication method with the MongoDB charm, all within the Juju ecosystem.
You’ll need:
Deploy an LDAP server in a K8s environment
In this guide, we use self-signed certificates provided by the self-signed-certificates operator.
This is not recommended for a production environment.
Check the collection of Charmhub operators that implement the tls-certificate interface.
Switch to the Kubernetes controller:
juju switch <k8s_controller>
Deploy the GLAuth charm:
juju add-model glauth
juju deploy postgresql-k8s --channel 14/stable --trust
juju deploy glauth-k8s --channel edge --trust
Integrate (formerly known as “relate”) glauth-k8s with both self-signed-certificates and postgresql-k8s:
juju integrate glauth-k8s self-signed-certificates
juju integrate glauth-k8s postgresql-k8s
Deploy the GLAuth-utils charm in order to manage LDAP users:
juju deploy glauth-utils --channel edge --trust
Integrate the two applications:
juju integrate glauth-k8s glauth-utils
You will then have to create users and groups using glauth-utils.
Expose cross-controller URLs
Enable the required MicroK8s plugin:
IPADDR=$(ip -4 -j route get 2.2.2.2 | jq -r '.[] | .prefsrc')
sudo microk8s enable metallb $IPADDR-$IPADDR
Deploy the Traefik charm in order to expose endpoints from the K8s cluster:
juju deploy traefik-k8s --trust
juju integrate traefik-k8s glauth-k8s:ingress
Expose cross-model relations
To offer the GLAuth interfaces, run:
juju offer glauth-k8s:ldap ldap
juju offer glauth-k8s:send-ca-cert send-ca-cert
Consume offers
Switch to the VM controller:
juju switch <lxd_controller>:<my-model>
Consume the LDAP offers:
juju consume <k8s_controller>:admin/glauth.ldap
juju consume <k8s_controller>:admin/glauth.send-ca-cert
Configure roles
With the MongoDB LDAP integration, you must define roles which names are the exact Distinguished Name (DN) of a group in the LDAP directory.
For example, if you have a group named ou=superheroes,ou=users,dc=glauth,dc=com, create a role such as:
db.createRole({role: 'ou=superheroes,ou=users,dc=glauth,dc=com', privileges: [], roles: [{'db': 'superdb', 'role': 'readWrite'}]})
Disclaimer: Glauth service returns all groups as members of the Organizational Unit (OU) users, meaning you must add ou=users in the DN of your group when creating your role.
At this stage, you can fine tune some parameters used by MongoDB using two config options:
For a MongoDB replica set:
juju config mongodb ldap-query-template="" ldap-user-to-dn-mapping=""
For a MongoDB sharded cluster:
juju config <config-server-name> ldap-query-template="" ldap-user-to-dn-mapping=""
  • ldap-query-template is the query template used to get the group of a user
  • ldap-user-to-dn-mapping is used to map usernames to LDAP Distinguished Names for the users.
Those two configuration parameters are explained in detail in the Percona Server for MongoDB documentation, and in the description of the two config options.
Example
John Doe is a member of the group ou=superheroes,ou=users,dc=glauth,dc=com.
To allow the user cn=johndoe,ou=superheroes,ou=users,dc=glauth,dc=com to authenticate using the username johndoe@superheroes, one could configure the following mapping:
juju config mongodb ldap-query-template="dc=glauth,dc=com??sub?(&(objectClass=posixGroup)(uniqueMember={USER}))" ldap-user-to-dn-mapping='[{"match": "([^@]+)@([^@]+)", "substitution": "cn={0},ou={1},ou=users,dc=glauth,dc=com"}]'
juju config <config-server-name> ldap-query-template="dc=glauth,dc=com??sub?(&(objectClass=posixGroup)(uniqueMember={USER}))" ldap-user-to-dn-mapping='[{"match": "([^@]+)@([^@]+)", "substitution": "cn={0},ou={1},ou=users,dc=glauth,dc=com"}]'
Enable LDAP
To enable LDAP authentication on MongoDB, integrate the MongoDB charm with the GLAuth charm.
juju integrate mongodb:ldap ldap:ldap
juju integrate mongodb:ldap-certificate-transfer send-ca-cert:send-ca-cert
juju integrate <config-server-name>:ldap ldap:ldap
juju integrate <config-server-name>:ldap-certificate-transfer send-ca-cert:send-ca-cert
If you are using the mongos router, integrate it with GLAuth charm in the same way as the MongoDB application. Mongos charm supports LDAP starting from revision 42.
When everything is stabilised, you will be able to log in using your username johndoe@superheroes and your LDAP password. You will inherit from the permissions granted by the roles corresponding to your LDAP groups.
Disable LDAP
You can disable LDAP by removing the relations with GLAuth.
If you are using the mongos router, also remove the relations it with GLAuth charm in the same way as the MongoDB application shown below:
juju remove-relation mongodb:ldap-certificate-transfer send-ca-cert:send-ca-cert
juju remove-relation mongodb:ldap ldap:ldap
juju remove-relation <config-server-name>:ldap-certificate-transfer send-ca-cert:send-ca-cert
juju remove-relation <config-server-name>:ldap ldap:ldap
