Charmed MongoDB Docs
Charmed MongoDB Operator
Overview
MongoDB is a popular NoSQL database application. It stores its data with JSON-like documents creating a flexible user experience with easy-to-use data aggregation for data analytics. In addition, it is a distributed database, so vertical and horizontal scaling come naturally.
Applications like MongoDB must be managed and operated in the production environment. This means that MongoDB application administrators and analysts who run workloads in various infrastructures should be able to automate tasks for repeatable operational work. Technologies such as software operators encapsulate the knowledge, wisdom and expertise of a real-world operations team and codify it into a computer program that helps to operate complex server applications like MongoDB and other databases.
Canonical has developed an open-source operator called Charmed MongoDB, making it easier to operate MongoDB. The Charmed MongoDB Virtual Machine (VM) operator deploys and operates MongoDB on physical, Virtual Machines (VM) and other wide range of cloud and cloud-like environments, including AWS, Azure, OpenStack and VMWare.
Charmed MongoDB (VM Operator) is an enhanced, open source and fully-compatible drop-in replacement for the MongoDB Community Edition with advanced MongoDB enterprise features. It simplifies the deployment, scaling, design and management of MongoDB in production in a reliable way. In addition, you can use the operator to manage your MongoDB clusters with automation capabilities. It also offers replication, TLS, password rotation, easy-to-use application integration, backup, restore, and monitoring.
Aside from a VM operator, Canonical also developed another operator called Charmed MongoDB (K8s operator) that operates in the Kubernetes environment, and you can see the documentation here.
Software and releases
Charmed MongoDB (VM Operator) is an enhanced, open source and fully-compatible drop-in replacement for the MongoDB Community Edition with advanced MongoDB enterprise features. This operator uses the Charmed MongoDB snap package, which offers more features than the MongoDB Community version, such as backup and restores, monitoring and security features.
To see the Charmed MongoDB features and releases, visit our Release Notes page. Currently the charm supports:
  • Replication
  • Password Rotation
  • User management
  • TLS
  • Backup & Restore
Charm version, environment and OS
A charm version is a combination of both the application version and / (slash) the channel, e.g. 5/stable, 5/candidate, 5/edge. The channels are ordered from the most stable to the least stable, candidate, and edge. More risky channels like edge are always implicitly available. So, if the candidate is listed, you can pull the candidate and edge. When stable is listed, all three are available.
You can deploy the charm a stand-alone machine or cloud and cloud-like environments, including AWS, Azure, OpenStack and VMWare.
The upper portion of this page describes the Operating System (OS) where the charm can run e.g. 5/stable is compatible and should run in a machine with Ubuntu 22.04 OS.
Security, Bugs and feature request
If you find a bug in this snap or want to request a specific feature, here are the useful links:
  • Raise issues or feature requests in Github
  • Security issues in the Charmed MongoDB Operator can be reported through LaunchPad. Please do not file GitHub issues about security issues.
  • Meet the community and chat with us if there are issues and feature requests in our Mattermost Channel
Contributing
Please see the Juju SDK docs for guidelines on enhancements to this charm following best practice guidelines, and CONTRIBUTING.md for developer guidance.
License
The Charmed MongoDB Operator is free software, distributed under the Apache Software License, version 2.0. See LICENSE for more information.
The Charmed MongoDB Operator is free software, distributed under the Apache Software License, version 2.0. It [installs/operates/depends on] MongoDB Community Version, which is licensed under the Server Side Public License (SSPL)
Trademark notice
MongoDB’ is a trademark or registered trademark of MongoDB Inc. Other trademarks are property of their respective owners.
Navigation
Level Path Navlink
1 tutorial Tutorial
2 t-overview 1. Introduction
2 t-setup-environment 2. Set up the environment
2 t-deploy-mongodb 3. Deploy MongoDB
2 t-managing-units 4. Manage your units
2 t-manage-passwords 5. Manage passwords
2 t-relate-mongodb 6. Relate your MongoDB to other applications
2 t-enable-security 7. Enable security
2 t-cleanup-environment 8. Cleanup your environment
1 how-to How To
2 h-manage-units Manage units
2 h-enable-encryption Enable encryption
2 h-manage-app Manage applications
2 h-configure-s3 Configure S3
2 h-create-and-list-backups Create and List Backups
2 h-restore-backup Restore a Backup
2 h-migrate-cluster-via-restore Cluster Migration with Restore
2 h-view-metrics View Metrics
1 reference Reference
2 r-requirements Requirements
2 r-actions Actions
2 r-configurations Configurations
2 r-libraries Libraries
Redirects
Mapping table
Path Location
