How to disable TLS
This guide assumes that you have a Charmed MongoDB deployment with TLS enabled. See How to enable TLS for more information.
To disable TLS encryption, remove the relation between your MongoDB applications and the TLS provider on the endpoint specific to the peer-to-peer or client-to-server communication.
You can disable peer-to-peer encryption alone, client-to-server encryption alone, or both at the same time.
Disable TLS in a replica set
Peer-to-peer
juju remove-relation self-signed-certificates mongodb:peer-certificates
Client-to-server
juju remove-relation self-signed-certificates mongodb:client-certificates
Disable TLS in a sharded cluster
Remove the relations from all the cluster components.
Peer-to-peer
juju remove-relation self-signed-certificates config-server:peer-certificates
juju remove-relation self-signed-certificates shard-one:peer-certificates
juju remove-relation self-signed-certificates shard-two:peer-certificates
You have successfully disabled peer-to-peer TLS encryption with for your sharded cluster.
Client-to-server
juju remove-relation self-signed-certificates config-server:client-certificates
juju remove-relation self-signed-certificates shard-one:client-certificates
juju remove-relation self-signed-certificates shard-two:client-certificates
You have successfully disabled client-to-server TLS encryption with for your sharded cluster.
