Manage Passwords
This is part of the Charmed MongoDB Tutorial. Please refer to this page for more information and the overview of the content.
Passwords
When we accessed MongoDB earlier in this tutorial, we needed to include a password in the URI. Passwords help to secure our database and are essential for security. Over time it is a good practice to change the password frequently. Here we will go through setting and changing the password for the admin user.
Retrieve the admin password
As previously mentioned, the admin password can be retrieved by running the get-password action on the Charmed MongoDB application:
juju run mongodb/leader get-password
Running operation 9 with 1 task
- task 10 on unit-mongodb-0
Waiting for task 10...
password: 9JLjd0tuGngW5xFKWWbo0Blxyef0oGec
The admin password is under the result: password.
Rotate the admin password
You can change the admin password to a new random password by entering:
juju run mongodb/leader set-password
Running operation 11 with 1 task
- task 12 on unit-mongodb-0
Waiting for task 12...
password: f3QkHE6QgmDLdRBonrt4vToWB7IZd4JO
The admin password is under the result: password. It should be different from your previous password.
Note when you change the admin password you will also need to update the admin password the in MongoDB URI; as the old password will no longer be valid. Update the DB password used in the URI and update the URI:
export DB_PASSWORD=$(juju run mongodb/leader get-password | grep password| awk '{print $2}')
export URI=mongodb://$DB_USERNAME:$DB_PASSWORD@$HOST_IP/$DB_NAME?replicaSet=$REPL_SET_NAME
Set the admin password
You can change the admin password to a specific password by entering:
juju run mongodb/leader set-password password=<password>
Running operation 17 with 1 task
- task 18 on unit-mongodb-0
Waiting for task 18...
password: <password>
The admin password under the result: password should match whatever you passed in when you entered the command.
Note that when you change the admin password you will also need to update the admin password in the MongoDB URI, as the old password will no longer be valid. To update the DB password used in the URI:
