Enable Security in your MongoDB deployment
This is part of the Charmed MongoDB 5 K8s Tutorial. Please refer to this page for more information and the overview of the content.
Transport Layer Security (TLS)
TLS is used to encrypt data exchanged between two applications; it secures data transmitted over the network. Typically, enabling TLS within a highly available database, and between a highly available database and client/server applications, requires domain-specific knowledge and a high level of expertise. Fortunately, the domain-specific knowledge has been encoded into Charmed MongoDB K8S. This means enabling TLS on Charmed MongoDB K8S is readily available and requires minimal effort on your end.
Again, relations come in handy here as TLS is enabled via relations; i.e. by relating Charmed MongoDB K8s to the Self Signed Certificates Charm. The Self Signed Certificates Charm centralises self-signed certificate management in a consistent manner and handles providing, requesting, and renewing self-signed TLS certificates.
Note: Only for the tutorial sake we will use self-signed certificates provided by self-signed-certificates-operator. For production environments you should use tls-certificates-operator.
Configure TLS
Before enabling TLS on Charmed MongoDB K8s we must first deploy the tls-certificates-operator charm:
juju deploy self-signed-certificates --channel=beta
Wait until the self-signed-certificates is ready to be configured. When it is ready to be configured watch -n 1 -c juju status. Will show:
tutorial overlord microk8s/localhost 3.1.6 unsupported 04:40:45Z
data-integrator active 1 data-integrator edge 13 10.152.183.196 no
mongodb-k8s active 2 mongodb-k8s 5/edge 27 10.152.183.194 no Primary
self-signed-certificates active 1 self-signed-certificates beta 33 10.152.183.116 no
data-integrator/0* active idle 10.1.137.151
mongodb-k8s/0* active idle 10.1.137.145 Primary
mongodb-k8s/1 active idle 10.1.137.149
self-signed-certificates/0* active idle 10.1.137.152
Enable TLS
After configuring the certificates watch -n 1 juju status will show the status of self-signed-certificates as active. To enable TLS on Charmed MongoDB K8s, relate the two applications:
juju relate mongodb-k8s self-signed-certificates
Connect to MongoDB with TLS
Like before, generate and save the URI that is used to connect to MongoDB:
export URI=mongodb://$DB_USERNAME:$DB_PASSWORD@$HOST_IP,$HOST_IP_1:27017/$DB_NAME?replicaSet=$REPL_SET_NAME
echo $URI
Now ssh into mongodb-k8s/0:
After sshing into mongodb-k8s/0, we are now in the unit that is hosting Charmed MongoDB K8s.
Once TLS has been enabled we will need to change how we connect to MongoDB. Specifically we will need to specify the TLS CA file along with the TLS Certificate file. These are on the units hosting the Charmed MongoDB K8S application in the folder /etc/mongod. If you enter: ls /etc/mongod/external* you should see the external certificate file and the external CA file:
/etc/mongod/external-ca.crt /etc/mongod/external-cert.pem
As before, we will connect to MongoDB via the saved MongoDB URI. Connect using the saved URI and the following TLS options:
mongosh <URI> --tls --tlsCAFile /etc/mongod/external-ca.crt --tlsCertificateKeyFile /etc/mongod/external-cert.pem
Note: be sure you wrap the URI in " with no trailing whitespace.
Congratulations, you’ve now connected to MongoDB with TLS. Now exit the MongoDB shell by typing:
exit
Now you should be back in the host of the Charmed MongoDB K8s’s unit: mongodb-k8s/0. To exit this host type:
exit
You should now be in the shell you started where you can interact with Juju and Kubernetes (Microk8s).
Disable TLS
To disable TLS, unrelate the two applications:
juju remove-relation mongodb-k8s self-signed-certificates
