Charmed MetalLB tutorial
The Charmed MetalLB Operator delivers automated operations management from day 0 to day 2 on the MetalLB Load Balancer Implementation for Bare Metal Kubernetes. It is an open source, production-ready charm on top of Juju
As a first step this tutorial shows you how to get Charmed MetalLB up and running, but the tutorial does not stop there. In this tutorial we will walk through how to:
- Set up an environment using Kubernetes and Juju.
- Deploy MetalLB using a single command.
- Configure the IPAddressPool.
What you’ll need
While this tutorial intends to guide and teach you as you deploy Charmed MetalLB, it will be most beneficial if you already have a familiarity with:
- Basic terminal commands.
- MetalLB concepts.
Before we start, make sure you can meet the following requirements:
- Access to the internet for downloading the required charms and containers
- Access to a Kubernetes Cloud either
- deployed via microk8s
- deployed via charmed-kubernetes
- or otherwise deployed
Represent the cloud in juju
Juju recognizes your MicroK8s cloud automatically. You can already see it if you run:
juju clouds
microk8s 1 localhost k8s 1 built-in A Kubernetes Cluster
If it is not there, you may add the cloud with:
KUBECONFIG=path/to/kubeconfig/file juju add-k8s --client <k8s-cloud>
Deploy Charmed MetalLB
The best way to deploy MetalLB in Layer 2 mode on Charmed Kubernetes is with the MetalLB charm, which activates both the metallb controller Deployment and metallb speaker DaemonSet.
Run the following command, which will fetch the charm from Charmhub and deploy it to your model:
juju deploy metallb --channel 1.28/stable --trust
Juju will now fetch Charmed MetalLB and begin deploying it to the Kubernetes cluster. This process can take several minutes depending on how provisioned (RAM, CPU, etc) your machine is. You can track the progress by running:
juju status --watch 1s
This command is useful for checking the status of Charmed MetalLB and gathering information about the containers hosting Charmed MetalLB. Some of the helpful information it displays include IP addresses, ports, state, etc. The command updates the status of Charmed MetalLB every second and as the application starts you can watch the status and messages of Charmed MetalLB change. Wait until the application is ready - when it is ready, juju status will show:
juju-metallb overlord k8s-cloud/default 3.1.5 unsupported 13:32:58-05:00
metallb active 1 metallb 1.28/stable 9 10.152.183.85 no
metallb/0* active idle 192.168.0.15
To exit the screen with juju status --watch 1s, enter Ctrl+c.
If you want to further inspect juju logs, can watch for logs with juju debug-log.
More info on logging at juju logs.
Configure MetalLB
You will need to change the IP addresses allocated to MetalLB to suit your environment. The IP addresses can be specified as a range, such as “192.168.1.88-192.168.1.89”, or as a comma-separated list of pools in CIDR notation, such as “192.168.1.240/28, 10.0.0.0/28”.
Configuring the IP addresses can be done either at time of deployment via single-line config or later by changing the charm config via Juju.
This will adjust the default IPAddressPool.spec.addresses created by the charm according to the specification
An example single-line config adjustment might look like:
juju deploy metallb --config iprange='192.168.1.88-192.168.1.89' --trust
Alternatively, you can change the config directly on the metallb charm at any time:
juju config metallb iprange="192.168.1.240/28, 10.0.0.0/28"
