Here’s how to set up the MAAS Operator Charm:
- Set up the environment
- Install the base packages
- Set up LXD
- Bootstrap the Juju controller
- Install PostgreSQL
- Install HAProxy
- Install MAAS
These steps are detailed below.
[!NOTE]
As of MAAS-Region latest/edge rev 212, logic for interacting with the MAAS Agent charm has been removed, and MAAS-Agent end-of-life. To continue using the MAAS-Agent charm, pin MAAS-Region latest/edge to 211.
The reccomended method, however, to maintain rack functionality is to follow the steps below and configure MAAS-Region rev 212 and upwards with enable_rack_mode=true.
You need to create some some environment variables to support this charm. Specifically, you need your LaunchPad ID and the specific location of the MAAS region and agent charms. Here’s how:
# LaunchPad ID
export LP_ID="my-lp-id"
export MAAS_REGION_CHARM=./maas-region-charm/maas-region_ubuntu-22.04-amd64.charm
Next, you need to install Juju, LXD, and Charmcraft, which form the foundation for this charm:
sudo snap install juju
sudo snap install lxd
sudo snap install charmcraft --classic
Juju needs to be invoked once to initialize its local state, including an SSH key that will be needed later.
# The actual command doesn't matter, just run Juju once
juju whoami
Set up LXD
Next, you need to set up LXD, since it’s part of this Charm configuration. Specifically, you’ll need networks, projects, profiles, and virtual machines before moving on to the next step.
Create networks
First, you’ll need managed network to act as the control plane:
lxc network create jujulab
lxc network edit jujulab <<EOF
description: "Juju lab network"
type: bridge
config:
dns.domain: juju-lab
ipv4.address: 10.70.0.1/24
ipv4.dhcp: "true"
ipv4.dhcp.ranges: 10.70.0.65-10.70.0.126
ipv4.nat: "true"
ipv6.address: none
EOF
Next, you must integrate this network with the host’s DNS service and make this integration persistent:
resolvectl dns jujulab 10.70.0.1
resolvectl domain jujulab '~juju-lab'
cat <<EOF | sudo tee /etc/systemd/system/lxd-dns-net-juju.service
[Unit]
Description=LXD per-link DNS configuration for jujulab
BindsTo=sys-subsystem-net-devices-jujulab.device
After=sys-subsystem-net-devices-jujulab.device
[Service]
Type=oneshot
ExecStart=/usr/bin/resolvectl dns jujulab 10.70.0.1
ExecStart=/usr/bin/resolvectl domain jujulab '~juju-lab'
ExecStopPost=/usr/bin/resolvectl revert jujulab
RemainAfterExit=yes
[Install]
WantedBy=sys-subsystem-net-devices-jujulab.device
EOF
sudo systemctl daemon-reload
sudo systemctl enable --now lxd-dns-net-juju
You’ll also need an unmanaged network for Devices-Under-Test (DUT):
lxc network create jujudata
lxc network edit jujudata <<EOF
description: "Juju test network"
type: bridge
config:
dns.domain: jujudata
ipv4.address: 10.70.1.1/24
ipv4.dhcp: "false"
ipv4.nat: "false"
ipv6.address: none
EOF
Now that the networks are set up, we’ll need a project and some profiles.
Create project and profiles
First, create a project to isolate the charm:
lxc project create juju-lab -c features.images=false
lxc project switch juju-lab
Next, create a profile for Juju controllers, which will use two network interface cards (NICs):
lxc profile create juju-host
lxc profile edit juju-host <<EOF
description: Juju host
config:
limits.cpu: 2
limits.memory: 4GB
user.user-data: |
#cloud-config
ssh_authorized_keys:
- $(cat ${HOME}/.ssh/id_rsa.pub | cut -d' ' -f1-2)
- $(cat ${HOME}/.local/share/juju/ssh/juju_id_rsa.pub | cut -d' ' -f1-2)
devices:
eth0:
type: nic
network: jujulab
eth1:
type: nic
network: jujudata
root:
path: /
pool: default
type: disk
EOF
Then, create a profile for devices under test (just one NIC this time):
lxc profile create juju-dut
lxc profile edit juju-dut <<EOF
description: Juju lab DUT
devices:
eth0:
type: nic
network: jujudata
root:
path: /
pool: default
type: disk
EOF
Create VMs
You’ll need some VMs to make this environment work, so create a few:
for h in $(seq 1 3); do \
lxc launch ubuntu:jammy "m$h" --vm -p juju-host;\
done;\
sleep 5;\
lxc exec "m$h" -- cloud-init status --wait;\
ssh-keyscan -H "m$h.juju-lab" >> ~/.ssh/known_hosts;\
done
Bootstrap Juju controller
Next, you’ll need to bootstrap the Juju controller:
cat >| maas-bootstrap.yaml <<EOF
clouds:
maas-bootstrap:
type: manual
endpoint: ubuntu@m1.juju-lab
regions:
default: {}
EOF
juju add-cloud maas-bootstrap ./maas-bootstrap.yaml
juju bootstrap maas-bootstrap maas-controller
juju add-machine -m controller ssh:ubuntu@m2.juju-lab
juju add-machine -m controller ssh:ubuntu@m3.juju-lab
juju enable-ha -n 3 --to 1,2
juju controllers --refresh
Now we’re ready to install the packages that add MAAS to the charm, using the charm itself to install and configure them.
Install Postgres DB
Deploy a MAAS-usable PostgreSQL DB using the charm itself:
juju deploy -m controller postgresql --channel 14/stable --series jammy --to 0
juju add-unit -m controller postgresql -n 2 --to 1,2
Install HAProxy
You can also deploy HAProxy using the charm:
juju deploy -m controller haproxy --series jammy --to 0 --channel=2.8/edge
juju add-unit -m controller haproxy -n 2 --to 1,2
Install MAAS
Finally, you can deploy MAAS using the charm, in several steps.
- Deploy a region-controller in Region+Rack mode using the charm
juju deploy -m controller ${MAAS_REGION_CHARM} --to 0
juju config maas-region enable_rack_mode=true
juju status --watch 10s # wait for it to initialize
- Make sure that Juju can consume offers from the region:
juju integrate -m controller maas-region postgresql
juju integrate -m controller maas-region:ingress-tcp haproxy:haproxy-route-tcp
juju status --watch 10s # wait for it to settle
- (Optionally) Enable TLS:
juju integrate -m controller maas-region:ingress-tcp-tls haproxy:haproxy-route-tcp
juju config -m controller maas-region ssl-cert-content $(cat certificate.cert)
juju config -m controller maas-region ssl-key-content $(cat certificate.key)
juju config -m controller maas-region ssl-cacert-content $(cat ca.cert) # Needed if the certificate is self-signed
- Create an Admin user:
juju run -m controller maas-region/leader create-admin username=maas password=maas email=maas@example.com ssh-import=lp:${LP_ID}
- Get the MAAS URL, which you’ll need to access your MAAS instance:
juju run -m controller maas-region/leader get-api-endpoint
Conclusion
That’s it! Your MAAS is up and running, using the MAAS Operator Charm.
