Charmed Kubeflow 1.6 to 1.7,kserve-controller hook failed
ERROR juju.worker.uniter.operation runhook.go:153 hook “install” (via hook dispatching script: dispatch) failed: exit status 1 After upgrading from Charmed Kubeflow 1.6 to 1.7, the kserve-controller fails to start and reports the above error. The web interface can still be accessed, however, when users attempt to log in, a ‘CSRF check failed’ error is displayed. This error may occur if the login form is opened in multiple tabs. Please attempt to log in again. Follow the tutorial How to upgrade Kubeflow from 1.6 to 1.7 | Documentation | Charmed Kubeflow kservo-controller log: 2023-06-13T13:27:12.906Z [container-agent] 2023-06-13 13:27:12 INFO juju.worker.uniter resolver.go:155 awaiting error resolution for “install” hook 2023-06-13T13:27:17.340Z [pebble] Check “readiness” failure 1320 (threshold 3): received non-20x status code 418 2023-06-13T13:27:27.342Z [pebble] Check “readiness” failure 1321 (threshold 3): received non-20x status code 418 2023-06-13T13:27:37.343Z [pebble] Check “readiness” failure 1322 (threshold 3): received non-20x status code 418 2023-06-13T13:27:47.343Z [pebble] Check “readiness” failure 1323 (threshold 3): received non-20x status code 418 2023-06-13T13:27:57.342Z [pebble] Check “readiness” failure 1324 (threshold 3): received non-20x status code 418 2023-06-13T13:28:07.343Z [pebble] Check “readiness” failure 1325 (threshold 3): received non-20x status code 418
