How to manage units
Replication and Scaling
Increasing the number of Kafka brokers can be achieved by adding more units to the Charmed Kafka K8s application, e.g.
juju add-unit kafka-k8s -n <num_brokers_to_add>
For more information on how to manage units, please refer to the Juju documentation
It is important to note that when adding more units, the Kafka cluster will not automatically rebalance existing topics and partitions. New storage and new brokers will be used only when new topics and new partitions are created.
Partition reassigment can still be done manually by the admin user by using the
/opt/kafka/bin/kafka-reassign-partitions.sh
Kafka bin utility script. Please refer to
its documentation for more information.
IMPORTANT Scaling down is currently not supported in the charm automation.
If partition reassignment is not manually performed before scaling down in order to makes sure the decommisioned units does not hold any data, your cluster may suffer to data loss.
Running Kafka Admin utility scripts
Apache Kafka ships with bin/*.sh
commands to do various administrative tasks such as:
bin/kafka-config.sh
to update cluster configurationbin/kafka-topics.sh
for topic managementbin/kafka-acls.sh
for management of ACLs of Kafka users
Please refer to the upstream Kafka project,
for a full list of the bash commands available in Kafka distributions. Also, you can
use --help
argument for printing a short summary of the argument for a given
bash command.
These scripts can be found in the /opt/kafka/bin
folder.
IMPORTANT Before running bash scripts, make sure that some listeners have been correctly opened by creating appropriate integrations. Please refer to this table for more information about how listeners are opened based on integrations. To simply open a SASL/SCRAM listener, just integrate a client application using the data-integrator, as described here.
To run most of the scripts, you need to provide:
- the Kafka service endpoints, generally referred to as bootstrap servers
- authentication information
Juju admins of the Kafka deployment
For Juju admins of the Kafka deployment, the bootstrap servers information can be obtained using
BOOTSTRAP_SERVERS=$(juju run kafka-k8s/leader get-admin-credentials | grep "bootstrap.servers" | cut -d "=" -f 2)
Admin client authentication information is stored in the
/etc/kafka/client.properties
file present on every Kafka
broker. The content of the file can be accessed using
juju ssh kafka-k8s/leader `cat /etc/kafka/client.properties`
This file can be provided to the Kafka bin commands via the --command-config
argument. Note that client.properties
may also refer to other files (
e.g. truststore and keystore for TLS-enabled connections). Those
files also need to be accessible and correctly specified.
Commands can be run within a Kafka broker, since both the authentication file (along with the truststore if needed) and the Charmed Kafka binaries are already present.
Example (Listing topics)
For instance, in order to list the current topics on the Kafka cluster, you can run:
juju ssh kafka-k8s/leader '/opt/kafka/bin/kafka-topics.sh --bootstrap-server $BOOTSTRAP_SERVERS --list --command-config /etc/kafka/client.properties'
Juju External users
For external users managed by the Data Integrator Charm, the endpoints and credentials can be fetched using the dedicated action
juju run data-integrator/leader get-credentials --format yaml
The client.properties
file can be generated by substituting the relevant information in the
file available on the brokers at /etc/kafka/client.properties
To do so, fetch the information using juju
commands:
BOOTSTRAP_SERVERS=$(juju run data-integrator/leader get-credentials --format yaml | yq .kafka.endpoints )
USERNAME=$(juju run data-integrator/leader get-credentials --format yaml | yq .kafka.username )
PASSWORD=$(juju run data-integrator/leader get-credentials --format yaml | yq .kafka.password )
Then copy the /etc/kafka/client.properties
and substitute the following lines:
sasl.jaas.config=org.apache.kafka.common.security.scram.ScramLoginModule required username="<USERNAME>" password="<PASSWORD>";
bootstrap.servers=<BOOTSTRAP_SERVERS>
