How to deploy on Azure
Azure is the cloud computing platform developed by Microsoft. It has management, access and development of applications and services to individuals, companies, and governments through its global infrastructure. Access the Azure web console at portal.azure.com.
Install Client Environment
WARNING: The current limitations:
- Only supported starting Juju 3.6 (currently edge)
- Juju cli should be on Azure VM for it to be able to reach cloud metadata endpoint.
- Managed Identity and the Juju resources should be on the same Azure subscription
- The current setup has been tested on Ubuntu 22.04+
Juju
Install Juju via snap:
sudo snap install juju --channel 3.6/edge
Check that the Juju version is correctly installed:
juju version
Output example
3.6-rc1-genericlinux-amd64
Azure CLI
Install the Azure CLI on Linux distributions by following the Azure CLI’s installation guide.
Verify that it is correctly installed:
az --version
Output example
azure-cli 2.65.0
core 2.65.0
telemetry 1.1.0
Dependencies:
msal 1.31.0
azure-mgmt-resource 23.1.1
Python location '/opt/az/bin/python3'
Extensions directory '/home/deusebio/.azure/cliextensions'
Python (Linux) 3.11.8 (main, Sep 25 2024, 11:33:44) [GCC 11.4.0]
Legal docs and information: aka.ms/AzureCliLegal
Your CLI is up-to-date.
Authenticate
For more information on how to authenticate, refer to the Juju documentation and a dedicated user guide on how to register Azure on Juju.
First of all, retrieve your subscription id:
az login
After authenticating via the web browser, you will be shown a list of information and a table with the subscriptions connected to your user, e.g.:
No Subscription name Subscription ID Tenant
[1] * <subscription_name> <subscription_id> canonical.com
[2] <other_subscription_name> <other_subscription_id> canonical.com
In the prompt, select the subscription id you would like to connect the controller to, and store the id as it will be needed in the next step when bootstrapping the controller.
Bootstrap Juju controller on Azure
First, you need to add a set of credentials to your Juju client:
juju add-credentials azure
This will start a script that will help you set up the credentials, where you will be asked:
credential-name— a sensible name that will help you identify the credential set, say<CREDENTIAL_NAME>region— a default region that is most convenient to deploy your controller and applications. Note that credentials are not region-specificauth type— authentication type. Selectinteractive, which is the recommended way to authenticate to Azure using Jujusubscription_id— the value<subscription_id>taken in the previous stepapplication_name— any unique string to avoid collision with other users or applicationsrole-definition-name— any unique string to avoid collision with other users or applications, and store it as<AZURE_ROLE>
Next, you will be asked to authenticate the requests via your web browser with the following message:
To sign in, use a web browser to open the page https://microsoft.com/devicelogin and enter the code <YOUR_CODE> to authenticate.
In the browser, open the authentication page and enter the code <YOUR_CODE> provided in the output.
You will be asked to authenticate twice, for allowing the creation of two different resources in Azure.
You will see a message that the credentials have been added locally:
Credential <CREDENTIAL_NAME> added locally for cloud "azure".
Once the credentials are correctly added, we can bootstrap a controller:
juju bootstrap azure <CONTROLLER_NAME>
Deploy charms
Create a new Juju model, if needed:
juju add-model <MODEL_NAME>
(Optional) Increase the debug level if you are troubleshooting charms:
juju model-config logging-config='<root>=INFO;unit=DEBUG'
Deploy and integrate Kafka and ZooKeeper:
juju deploy zookeeper -n3 --channel 3/stable [--constraints "instance-type=<INSTANCE_TYPE>"]
juju deploy kafka -n3 --channel 3/stable [--constraints "instance-type=<INSTANCE_TYPE>"]
juju integrate kafka zookeeper
Note that the smallest instance types on Azure may not have enough resources for hosting
an Apache Kafka broker. We recommend selecting an instance type that provides at the very least 8 GB of RAM and 4 cores, e.g. Standard_A4_v2.
For more guidance on production environment sizing, see the Requirements page.
You can find more information about the available instance types in the Azure documentation.
We also recommend to deploy a Data Integrator for creating an admin user to manage the content of the Kafka cluster:
juju deploy data-integrator admin --channel edge \
--config extra-user-roles=admin \
--config topic-name=admin-topic
And integrate it with the Kafka application:
juju integrate kafka admin
For more information on Data Integrator and how to use it, please refer to the how-to manage applications guide.
Clean up
Always clean Azure resources that are no longer necessary! Abandoned resources are tricky to detect and they can become expensive over time.
To list all controllers that have been registered to your local client, use the juju controllers command.
To destroy the Juju controller and remove the Azure instance (Warning: all your data will be permanently removed):
juju destroy-controller <CONTROLLER_NAME> --destroy-all-models --destroy-storage --force
Should the destroying process take a long time or be seemingly stuck, proceed to delete VM resources also manually via the Azure portal. See Azure documentation for more information on how to remove active resources no longer needed.
Next, check and manually delete all unnecessary Azure VM instances, to show the list of all your Azure VMs run the following command (make sure to use the correct region):
az resource list
List your Juju credentials with the juju credentials command.
Output example
Client Credentials:
Cloud Credentials
azure NAME_OF_YOUR_CREDENTIAL
Remove Azure CLI credentials from Juju:
juju remove-credential azure NAME_OF_YOUR_CREDENTIAL
After deleting the credentials, the interactive process may still leave the role resource and its assignment hanging around.
We recommend checking if these are still present by running:
az role definition list --name <AZURE_ROLE>
To get the full list, use it without specifying the --name argument.
You can check whether you still have a
role assignment bound to <AZURE_ROLE> registered by using:
az role assignment list --role <AZURE_ROLE>
If there is an unwanted role left, you can remove the role assignment first and then the role itself with the following commands:
az role assignment delete --role <AZURE_ROLE>
az role definition delete --name <AZURE_ROLE>
Finally, log out from Azure CLI:
az logout
