@pmatulis great, thank you.
I also have a correction and suggestions for the current Replacing OSD disks | Ubuntu setup.
Getting OSD FSID
The sudo ceph-volume lvm list | grep -A 12 "= osd.4 =" | grep 'osd fsid'
does not work Ceph 16.2.7
ubuntu@hcc-store40:~$ sudo ceph-volume lvm list | grep -A 12 "= osd.4 =" | grep 'osd fsid'
ubuntu@hcc-store40:~$ sudo ceph-volume lvm list | grep -A 12 "= osd.1 ="
====== osd.1 =======
[block] /dev/ceph-6f7f2d54-f2d0-4c20-82c4-27c009d3d651/osd-block-6f7f2d54-f2d0-4c20-82c4-27c009d3d651
block device /dev/ceph-6f7f2d54-f2d0-4c20-82c4-27c009d3d651/osd-block-6f7f2d54-f2d0-4c20-82c4-27c009d3d651
block uuid ZjSo1W-CItM-pUpB-S9Kc-rndf-0yY7-iSB6nb
cephx lockbox secret AQCQZWZiYSfFMhAAmog8ySZLrc1H1uGDOE1DMw==
cluster fsid cb9da1fc-c170-11ec-90b7-21377ec761fd
cluster name ceph
crush device class None
db device /dev/ceph-db-41cc6a7d-03e7-4bf9-8630-2c18ed491cc7/osd-db-6f7f2d54-f2d0-4c20-82c4-27c009d3d651
db uuid PARz39-hP20-dogJ-hS3W-1VYg-08ov-efNLEh
encrypted 1
ubuntu@hcc-store40:~$ sudo ceph-volume lvm list | grep -A 14 "= osd.1 ="
cluster name ceph
encrypted 1
osd fsid 6f7f2d54-f2d0-4c20-82c4-27c009d3d651
osd id 1
ubuntu@hcc-store40:~$ sudo ceph-volume lvm list | grep -A 14 "= osd.1 =" | grep 'osd fsid'
Other alternatives might be:
ceph osd find 1
ceph osd find 1 | jq .osd_fsid
ceph-volume lvm list /dev/sda | grep 'osd fsid'
ceph-volume lvm list --format json | jq '."1"[0].tags."ceph.osd_fsid"'
Cleaning up OSD resources
Instead of running cryptsetup close
and vgremove
manually, use
ceph-volume lvm deactivate [osd_id]
Deactivate unmounts and OSDs tmpfs and closes any crypt devices
ceph-volume lvm zap --destroy --osd-id [osd_id]
This will remove relevant LVs/VGs (including DB which is not handled currently in docs). This can also take VG/LV or paths if that’s more relevant for the docs.
N.B. One still has to run pvremove
in order to remove LVM label as workaround for Bug #1967295 “zap-disk action fails to zap device part of LVM wh...” : Bugs : Ceph OSD Charm
Safety checks
I would also recommend to add some safety checks such as ceph osd ok-to-stop
and ceph osd safe-to-destroy
as long as the guide does not use the remove-disk
action which has these checks.
