Integrate with applications
This guide shows how to integrate Charmed Apache Kyuubi K8s with both charmed and non-charmed applications.
Charmed applications
Integrations with charmed applications are supported via the kyuubi_client interface.
You can see which existing charms are compatible with Kyuubi in the Integrations tab on Charmhub.
The kyuubi_client interface
To integrate, run
juju integrate kyuubi-k8s:database <charm>
To remove the integration, run
juju remove-relation kyuubi-k8s <charm>
Non-charmed applications
To integrate with an application outside of Juju, use the data-integrator charm to create the required credentials and endpoints.
Deploy the data-integrator charm:
juju deploy data-integrator --config database-name=<name>
Integrate with Charmed Apache Kyuubi K8s:
juju integrate data-integrator kyuubi-k8s
Use the get-credentials action to retrieve credentials from data-integrator:
Rotate application password
To rotate the passwords of a user created for an integrated application, the associated integration must be removed and created again. This process will generate a new user and password for the application.
juju remove-relation <charm> kyuubi-k8s
juju integrate <charm> kyuubi-k8s
For a non-charmed application, the data-integrator is the <charm> to remove and re-create the integration with.
