Cluster replication
This How-To will cover how to set up cluster replication using MirrorMaker through Kafka Connect.
For a brief explanation of how MirrorMaker works, see the MirrorMaker explanation page.
Pre-requisites
To set up cluster replication we need:
- Two Charmed Apache Kafka clusters:
- An “active” source cluster to replicate from.
- A “passive” target cluster to replicate to.
- A Charmed Kafka Connect cluster to run the MirrorMaker connectors.
It is best practice to co-locate the Kafka Connect cluster with the target Apache Kafka cluster - for example in the same cloud region.
For guidance on how to set up Charmed Apache Kafka, please refer to the following resources:
- The Charmed Apache Kafka Tutorial
- The How to deploy guide for Charmed Apache Kafka
- The Charmed Kafka Connect Tutorial
Deploy a MirrorMaker integrator
The MirrorMaker integrator charm manages tasks on a Charmed Kafka Connect cluster that replicates data from an active Apache Kafka cluster to a passive cluster.
Current deployment
Check the status of deployed applications by running juju status command. The result should be similar to:
k vms localhost/localhost 3.6.3 unsupported 10:45:37+02:00
active 3.9.0 active 1 kafka 3/edge 205 no
passive 3.9.0 active 1 kafka 3/edge 205 no
kafka-connect active 1 kafka-connect latest/edge 20 no
active/0* active idle 0 10.86.75.171 19092/tcp
passive/0* active idle 1 10.86.75.153 9092,19092/tcp
kafka-connect/0* active idle 2 10.86.75.45 8083/tcp
To integrate Kafka Connect with the passive cluster (as recommened for active-passive replication), run:
juju integrate kafka-connect passive
Set up active-passive replication
First, deploy the MirrorMaker integrator charm:
juju deploy mirrormaker-connect-integrator mirrormaker
After some time the app should show up in the model as blocked:
mirrormaker/0* blocked idle 4 10.86.75.16 Integrator not ready to start, check if all relations are setup successfully
Set up the necessary relations:
juju integrate kafka-connect mirrormaker
juju integrate mirrormaker:source active
juju integrate mirrormaker:target passive
After some time, the mirrormaker application should show up as active/idle in the juju status:
k vms localhost/localhost 3.6.3 unsupported 10:59:37+02:00
mirrormaker active 1 mirrormaker 0 no Task Status: UNASSIGNED
active/0* active idle 0 10.86.75.171 9092,19092/tcp
mirrormaker/0* active idle 3 10.86.75.189 8080/tcp Task Status: UNASSIGNED
[note]
Task status might show as UNASSIGNED since there are no replication tasks running yet. If the active Kafka cluster is idle, this is expected. The task status will change to RUNNING once the replication tasks are created and started.
[\note]
With this, the deployment is complete. The Charmed Kafka Connect cluster will now start tasks to replicate data from the active cluster to the passive cluster.
Set up active-active replication
MirrorMaker allows for a deployment where both clusters are active. This means that data can be replicated from both clusters to each other. This is done by creating a MirrorMaker connector for each cluster. Two flows are needed in this scenario, one from cluster A to cluster B and one from cluster B to cluster A.
In essence, it is equivalent to do two active-passive deployments, one for each direction.
We recommend having two Kafka Connect deployments ready, one on each end of the replication.
Deployment
To ensure that the topics are prefixed with the cluster name and do not collide with each other, deploy two different Mirrormaker integrators with the config option prefix_topics=true:
juju deploy mirrormaker-connect-integrator --config prefix_topics=true mirrormaker-a-b
juju deploy mirrormaker-connect-integrator --config prefix_topics=true mirrormaker-b-a
kafka-a 3.9.0 active 1 kafka 3/edge 205 no
kafka-b 3.9.0 active 1 kafka 3/edge 205 no
kafka-connect-a active 1 kafka-connect latest/edge 20 no
kafka-connect-b active 1 kafka-connect latest/edge 20 no
mirrormaker-a-b active 1 mirrormaker 0 no Task Status: UNASSIGNED
mirrormaker-b-a active 1 mirrormaker 0 no Task Status: UNASSIGNED
kafka-a/0* active idle 0 10.86.75.171 9092,19092/tcp
kafka-b/0* active idle 1 10.86.75.153 9092,19092/tcp
kafka-connect-a/0* active idle 2 10.86.75.45 8083/tcp
kafka-connect-b/0* active idle 2 10.86.75.46 8083/tcp
mirrormaker-a-b/0* active idle 3 10.86.75.189 8080/tcp Task Status: UNASSIGNED
mirrormaker-b-a/0* active idle 3 10.86.75.190 8080/tcp Task Status: UNASSIGNED
Then the integrations needed should be done like follows:
# active-passive A -> B
juju integrate kafka-connect-b kafka-b
juju integrate kafka-connect-b mirrormaker-a-b
juju integrate mirrormaker-a-b:source kafka-a
juju integrate mirrormaker-a-b:target kafka-b
# active-passive B -> A
juju integrate kafka-connect-a kafka-a
juju integrate kafka-connect-a mirrormaker-b-a
juju integrate mirrormaker-b-a:source kafka-b
juju integrate mirrormaker-b-a:target kafka-a
With this, the deployment is complete. There will be two bi-directional replication flows between kafka-a and kafka-b. The topics will be prefixed with the cluster name, so that they do not collide with each other.
For example, a topic called demo created on kafka-a will be replicated as a new topic on kafka-b named kafka-a.replica.demo, and vice versa.
