Charmcraft supports the development of operators using the Charmed Operator Framework. It enables developers to build, upload and release operators on Charmhub and collaboration through charm libraries.
This new version was just released to candidate channel, we’d appreciate any tests on this, please report here any issues you find. Once we find this is solid enough, we will release it to stable.
It includes the following changes:
Several performance related improvements:
Reuse already installed dependencies from last run if requirements didn’t change
Faster launch of existing containers when packing charms
Improved user experience:
Show lifecycle step progress (related issue)
The deprecated ‘build’ command is now hidden and ‘pack’ appears more prominently in the help messages (related issue)
Better error messages in a couple of commands
Fixed interaction with user when asking if to install Multipass in Windows (related issue)
Enabled
craftclfrom Craft Parts scriptlets to be able to run the overridden step’s built-in handler (related issue) -
Full logs from building container are always retrieved, even after a success
pack(related issue) -
Updated the
opsframework version in theinittemplate -
Fixed a bug in libraries handling so disk paths are always importable (related issue)
Fixed which remote image was used by Multipass provider
Save the content of
CHARMCRAFT_IMAGE_INFOenvironment variable into the Charm’s manifest
Use Charmcraft to:
- Pack your Charmed Operator into a charm for distribution
Happy charming!
