Charmcraft supports the development of operators using the Charmed Operator Framework. It enables developers to build, upload and release operators on Charmhub and collaboration through charm libraries.
This new micro release includes the following change:
- Added a
charm-python-packagesplugin property so any Python package can be installed before the charm packing happens.
Use Charmcraft to:
- Build your Charmed Operator into a charm for distribution
Happy charming!
