Charmcraft supports the development of operators using the Charmed Operator Framework. It enables developers to build, upload and release operators on Charmhub and collaboration through charm libraries.
This new micro release includes the following changes:
Fixed a bug where previously packed and now deleted files were being included anyway in the final charm file (please do
charmcraft cleanto clean up possible leftovers from previous version). -
Include more files by default in the charm (if present, as they are optional):
icon.svg,README.mdandLICENSE.
Use Charmcraft to:
- Build your Charmed Operator into a charm for distribution
Happy charming!
