Charmcraft supports the development of operators using the Charmed Operator Framework. It enables developers to build, upload and release operators on Charmhub and collaboration through charm libraries.
This new version was just released to candidate channel, we’d appreciate any tests on this, please report here any issues you find. Once we find this is solid enough, we will release it to stable.
It includes the following changes:
The Charm and Bundle packing is now done through a parts lifecycle process in the same manner as
snapcraft.- the charm’s requirements and entrypoint can now be specified in the config, to simplify repetitive packing.
- it opens a world of possibilities to pack charms and bundles: explore the parts lifecycle docs if you have special packaging requirements.
Introduced a mechanism to validate that the charm was built using the best charm crafting practices (see all analyzers and linters).
- this infrastructure is run automatically when packing the charm, aborting the process if problems are found (can be overruled with
--force). - all linters and checkers can be called explicitly using the new
analyzecommand (use--format=jsonto produce a machine-consumable output). - these verifications can be explicitly ignored (see
analysiskey in the config).
The packing procedure no longer includes all the project’s files by default (see this forum post for further reference).
When packing charms in Charmcraft-driven LXD containers, perform additional validation of LXD configuration and user permissions to improve user experience.
Introduced
--destructive-modeoption to pack charm on host instead of using an LXD container (use with caution as this mode allows changes to system configuration). -
Fixed a regression when listing revisions and showing status for bundles.
Use Charmcraft to:
- Build your Charmed Operator into a charm for distribution
Happy charming!
