Charmcraft supports the development of operators using the Charmed Operator Framework. It enables developers to build, upload and release operators on Charmhub and collaboration through charm libraries.
This new release includes the following change:
- Allow including resources when releasing charms directly in the upload command; this fixes the regression documented here.
Use Charmcraft to:
- Build your Charmed Operator into a charm for distribution
Happy charming!
