Charmcraft supports the development of operators using the Charmed Operator Framework. It enables developers to build, upload and release operators on Charmhub and collaboration through charm libraries.
This new release includes the following changes:
The upload-resource command was improved for OCI Images
- they are now uploaded from the local Docker Repository
- related specification
The charm is now built in a LXD container, allowing the process to be done in a different base than the host
- the Charmcraft config now has a
basesentry to express where the charm can be built and where it can run (short and long forms supported) - this configuration is optional for now but will be mandatory in the future (see deprecation notices DN02 and DN03)
- use of bases enables building in LXD
- the Charm resulting file name reflects where it was built
- Charmcraft now uses the
craft_providerslibrary, allowing in the future to build using Multipass instances - added a
cleancommand to remove any structures that were used for the building - related specification)
The
statuscommand output now includes a column for the charm bases- it shows the base name, channel and architecture
The keywords in Charmcraft configuration are now separated using dashes (see deprecation notice DN01)
Some UX improvements
- filepaths are shown in a consistent style
- some help messages adjusted
- better error messages when the
charmcraft.yamlconfig has issues
The Charmcraft snap is now
classicconfined- the snap is the recommended way to install and use the tool
Other internal Charmcraft improvements
- Python 3.6 and greater is now supported
- started to use black for consistent and automated formatting
- refactored how the project’s dependencies are handled
- migrated to use pydantic in the configuration manager
Use Charmcraft to:
- Build your Charmed Operator into a charm for distribution
Happy charming!
