`charmcraft login`
Usage:
charmcraft login [options]
Summary:
Login to Charmhub.
Charmcraft will provide a URL for the Charmhub login. When you have successfully logged in, charmcraft will store a token for ongoing access to Charmhub at the CLI (if --export option was not used otherwise it will only save the credentials in the indicated file).
Remember to charmcraft logout if you want to remove that token from your local system, especially in a shared environment.
If the credentials are exported, they can also be attenuated in several ways specifying their time-to-live (--ttl), on which channels would work (--channel), what actions will be able to do (--permission), and on which packages they will work (using --charm or --bundle).
See also charmcraft whoami to verify that you are logged in.
Options:
       -h, --help:  Show this help message and exit
    -v, --verbose:  Show debug information and be more verbose
      -q, --quiet:  Only show warnings and errors, not progress
      -t, --trace:  Show all information needed to trace internal
                    behaviour
-p, --project-dir:  Specify the project's directory (defaults to
                    current)
         --export:  The file to save the credentials to
          --charm:  The charm(s) on which the required credentials
                    would work (this option can be indicated
                    multiple times; defaults to all)
         --bundle:  The bundle(s) on which the required credentials
        --channel:  The channel(s) on which the required credentials
                    multiple times, defaults to any channel)
     --permission:  The permission(s) that the required credentials
                    will have (this option can be indicated multiple
                    times, defaults to all permissions)
            --ttl:  The time-to-live (in seconds) of the required
                    credentials (defaults to 30 hours)
See also:
close
create-lib
fetch-lib
list-lib
logout
names
publish-lib
register
register-bundle
release
resource-revisions
resources
revisions
status
upload
upload-resource
whoami
For a summary of all commands, run charmcraft help --all.
