The django-framework
Charmcraft extension includes configuration options customised for a Django application. This document describes all the keys that a user may interact with.
If you’d like to see the full contents contributed by this extension:
See How to manage extensions.
Database requirement
Django requires a database to function. When generating a new project, the default is to make use of SQLite^. Using SQLite is not recommended for production, especially on Kubernetes deployments, because the database is not shared across units and any contents will be removed upon a new container being deployed. The django-framework
extension therefore requires a database integration for every application, such as PostgreSQL^ or MySQL^. See the how-to guide for how to deploy a database and integrate the Django application with it.
charmcraft.yaml
> config
> options
You can use the predefined options (run charmcraft expand-extensions
for details) but also add your own, as needed.
In the latter case, any option you define will be used to generate environment variables; a user-defined option config-option-name
will generate an environment variable named DJANGO_CONFIG_OPTION_NAME
where the option name is converted to upper case, dashes will be converted to underscores and the DJANGO_
prefix will be added.
In either case, you will be able to set it in the usual way by running juju config <application> <option>=<value>
. For example, if you define an option called token
, as below, this will generate a DJANGO_TOKEN
environment variable, and a user of your charm can set it by running juju config <application> token=<token>
config:
options:
token:
description: The token for the service.
type: string
charmcraft.yaml
> peers
, provides
, requires
Your charm already has some peers
, provides
, and requires
integrations, for internal purposes.
Expand to view pre-loaded integrations
peers:
secret-storage:
interface: secret-storage
provides:
metrics-endpoint:
interface: prometheus_scrape
grafana-dashboard:
interface: grafana_dashboard
requires:
logging:
interface: loki_push_api
ingress:
interface: ingress
limit: 1
In addition to these integrations, in each provides
and requires
block you may specify further integration endpoints, to integrate with the following charms and bundles:
- Ingress: traefik and nginx ingress integrator
- MySQL: machine and k8s charm
- PostgreSQL: machine and k8s charm
- MongoDB
- Canonical Observability Stack (COS)
- Redis
- SAML
- S3
- RabbitMQ: machine and k8s charm
These endpoint definitions are as below:
requires:
mysql:
interface: mysql_client
optional: True
limit: 1
requires:
postgresql:
interface: postgresql_client
optional: True
limit: 1
requires:
mongodb:
interface: mongodb_client
optional: True
limit: 1
requires:
redis:
interface: redis
optional: True
limit: 1
requires:
saml:
interface: saml
optional: True
limit: 1
requires:
s3:
interface: s3
optional: True
limit: 1
requires:
rabbitmq:
interface: rabbitmq
optional: True
limit: 1
To add one of these integrations, e.g. PostgreSQL, in the charmcraft.yaml
file include the appropriate requires block and integrate with juju integrate <django charm> postgresql
as usual.
After the integration has been established, the connection string will be
available as an environment variable. Integration with PostgreSQL, MySQL, MongoDB or Redis provides the string as the POSTGRESQL_DB_CONNECT_STRING
, MYSQL_DB_CONNECT_STRING
MONGODB_DB_CONNECT_STRING
or REDIS_DB_CONNECT_STRING
environment variables respectively. Furthermore, the following environment variables will be provided to your Django application for integrations with PostgreSQL, MySQL, MongoDB or Redis:
<integration>_DB_SCHEME
<integration>_DB_NETLOC
<integration>_DB_PATH
<integration>_DB_PARAMS
<integration>_DB_QUERY
<integration>_DB_FRAGMENT
<integration>_DB_USERNAME
<integration>_DB_PASSWORD
<integration>_DB_HOSTNAME
<integration>_DB_PORT
<integration>_DB_NAME
Here, <integration>
is replaced by POSTGRESQL
, MYSQL
MONGODB
or REDIS
for the relevant integration. The key optional
with value False
means that the charm will get blocked and stop the services if the integration is not provided.
The provided SAML environment variables are as follows:
SAML_ENTITY_ID
(required)SAML_METADATA_URL
(required)SAML_SINGLE_SIGN_ON_REDIRECT_URL
(required)SAML_SIGNING_CERTIFICATE
(required)
The S3 integration creates the following environment variables that you may use to configure your Flask application: :
S3_ACCESS_KEY
(required)S3_SECRET_KEY
(required)S3_BUCKET
(required)S3_REGION
S3_STORAGE_CLASS
S3_ENDPOINT
S3_PATH
S3_API_VERSION
S3_URI_STYLE
S3_ADDRESSING_STYLE
S3_ATTRIBUTES
S3_TLS_CA_CHAIN
The RabbitMQ integration creates the connection string in the environment variable RABBITMQ_CONNECT_STRING
. Furthermore, the following environment variables may be provided, derived from the connection string:
RABBITMQ_SCHEME
RABBITMQ_NETLOC
RABBITMQ_PATH
RABBITMQ_PARAMS
RABBITMQ_QUERY
RABBITMQ_FRAGMENT
RABBITMQ_USERNAME
RABBITMQ_PASSWORD
RABBITMQ_HOSTNAME
RABBITMQ_PORT
RABBITMQ_VHOST
The environment variable DJANGO_BASE_URL
provides the Ingress URL for an Ingress integration or the Kubernetes service URL if there is no Ingress integration.
HTTP Proxy
Proxy settings should be set as model configurations. Charms generated using the django-framework
extension will make the Juju proxy settings available as the HTTP_PROXY
, HTTPS_PROXY
and NO_PROXY
environment variables. For example, the juju-http-proxy
environment variable will be exposed as HTTP_PROXY
to the Django service.
See more: Juju | List of model configuration keys
Background Tasks
Extra services defined in the file rockcraft.yaml
^ with
names ending in -worker
or -scheduler
will be passed the same environment variables as the main application. If there is more than one unit
in the application, the services with the name ending in -worker
will run in all units. The services with name ending in -scheduler
will
only run in one of the units of the application.
Secrets
Juju secrets can be passed as environment variables to your Django application.
The secret ID has to be passed to the application as a config option in the
file charmcraft.yaml
file of type secret
. This config option has to be populated with the secret
ID, in the format secret:<secret ID>
The environment variable name passed to the application will be:
DJANGO_<config option name>_<key inside the secret>
The <config option name>
and <key inside the secret>
keywords in the environment variable name
will have the hyphens replaced by underscores and all the letters capitalised.
See more: Secret
