Command 'charmcraft create-lib'
Usage:
charmcraft create-lib [options] <name>
Summary:
Create a charm library.
Charmcraft manages charm libraries, which are published by charmers to help other charmers integrate their charms. This command creates a new library in your charm which you are publishing for others.
This command MUST be run inside your charm directory with a valid charmcraft.yaml. It will create the Python library with API version 0 initially:
lib/charms/<yourcharm>/v0/<name>.py
Each library has a unique identifier assigned by Charmhub that supports accurate updates of libraries even if charms are renamed. Charmcraft will request a unique ID from Charmhub and initialise a template Python library.
Creating a charm library will take you through login if needed.
Options:
-h, --help Show this help message and exit
-v, --verbose Show debug information and be more verbose
-q, --quiet Only show warnings and errors, not progress
--verbosity Set the verbosity level to ‘quiet’, ‘brief’, ‘verbose’, ‘debug’ or ‘trace’
-p, --project-dir Specify the project’s directory (defaults to current)
--format Produce the result in the specified format (currently only ‘json’)
See also:
  • close
  • fetch-lib
  • list-lib
  • login
  • logout
  • names
  • promote-bundle
  • publish-lib
  • register
  • register-bundle
  • release
  • resource-revisions
  • resources
  • revisions
  • status
  • unregister
  • upload
  • upload-resource
  • whoami
