Charmcraft supports the development of operators using the Charmed Operator Framework . It enables developers to build, upload and release operators on Charmhub and collaboration through charm libraries.
New Release
Charmcraft 2.6.0 was just released to the
Charmcraft 2.6.0 was just released to the latest/candidate channel. We are running a broad set of tests and will likely promote it to stable shortly.latest/stable and 2.x/stable channels.
Changes
- Charmcraft 2.6 supports the
secretconfiguration type incharmcraft.yaml - Bump library versions, fixing LXD 5.21 incompatibility. Please note that earlier Charmcraft versions will not receive this fix.
Using Charmcraft
- Pack your Charmed Operator into a charm for distribution
Happy charming!
