Charm Tech pulse 2026#22-23
This busy pulse saw many releases: Ops 3.10.0, Jubilant 1.15.0, Concierge 1.10.0, Charmlint 0.4.0, charmlibs.snap 2.1.0 and 2.2.0, and charmlibs.pathops 1.4.0 and 1.4.1. The Hyrum documentation is now hosted at canonical.com/juju/docs/hyrum, and we added several new documentation pages: How to set up production integrations, How to document an interface, and How to migrate your charm to a charmlibs package.
Ops
  • Released Ops 3.10.0.
  • Added a Hypothesis property test suite to Ops, with a nightly run (#2869). Worked on running the property-tests branch’s tests nightly (#2897) and adding property tests for Pebble multipart parsing and Go time parsing (#2911).
  • Progressed the multi-charm testing work: finding a charm’s Python dependencies from its build plugin (#2880), running a charm’s events in a persistent worker process (#2902), and, in draft, a private multi-charm model (#2913) with peer relations (#2914) and config / to_context (#2915).
  • Modelled juju-*-proxy model configs from Juju (#2832).
  • Fixed a variety of small ops bugs (#2851, #2870, #2855, #2901, #2857, #2878, #2877, #2876, #2875, #2872, #2871).
Charming
  • Released Charmlint 0.4.0, with three new rules.
  • Released Concierge 1.10.0, which will log the version and revision when installing snaps (#273).
  • Released Jubilant 1.15.0, which will report wait duration, support refresh’s switch option, and --ssh-key in ssh and scp.
  • Let the Hyrum charm list pin a repository to a commit (#215), and worked on keeping markers and scope companions to the arrays that declare ops in uv projects (#213), and patching ops in local path dependencies inside the repository (#214).
  • Fixed a dependency issue in pytest-jubilant, which now requires Jubilant 1.7, which added Juju.model_constraints (#138).
  • Changed the Jubilant integration tests to use the 3.6 track instead of 3 (#468).
  • Drafted a spec for modelling Pebble service behaviour in ops.testing.
  • Drafted a spec for generating charmcraft YAML from Python classes.
  • Started work on a spec for property testing in multiple-charm tests.
Charmlibs
  • Added How to document an interface (#546).
  • Added How to migrate your charm to a charmlibs package (#785).
  • Added snap.system_info() and SystemInfo.architecture in 2.1.0, which lets charms find the system’s userspace architecture, useful for choosing the correct snap revision to install (#784).
  • Added snap.ensure_vitality_hint in 2.2.0, which charms can call to protect their snaps’ services from the OOM killer (#709).
  • Released pathops 1.4.0, which adds ContainerPath.is_relative_to, PathProtocol.with_stem (including ContainerPath implementation), and improvements to ContainerPath.match (#761).
  • Updated ContainerPath.is_symlink, rmdir, and unlink to treat names literally rather than as patterns in pathops 1.4.1 (#765).
  • Moved Charmlibs integration tests to pytest-jubilant’s juju fixture: the template and examples (#775), pathops (#776), rollingops (#777), and nginx_k8s (#779), with sloth in progress (#778).
  • Made updates and corrections to interface schemas (#661, #738, #746).
  • Fixed flaky tests: used the fish release-4 PPA for the apt higher-version test (#787), waited for the systemd test service to reach the failed state (#788), accepted snapd 2.78 wording for invalid option names (#783), and waited for in-progress snap auto-refreshes to complete mid-test (#747).
  • Added CODEOWNERS to remaining interfaces (#733) and add a CI check to ensure all code has an owner (#587).
  • Made improvements and fixes to the library documentation build process (#637, #808 , #809).
  • In kratos_external_idp: worked on comparing the provider enum in the schema validators (#781).
  • Worked on setting ownership and mode before writing file contents in pathops (#773), running the K8s integration tests on Canonical K8s (#772), and a --format-only option for just format (#771).
Pebble
  • Added a package for parsing and evaluating schedule strings, groundwork for scheduling in Pebble (#1138)
  • Finalised schedule syntax parsing (#1138)
  • Fixed bug around memory usage in log backscroll (#1135)
  • Worked on adding an option to gate a service on startup health checks succeeding before it enters the “running” state, with a new on-check-success option added to services in plan layers (#1156)
  • Fixed prometheus metrics names for conformance (#1124)
  • Reject non-positive period in check validation (#1126)
  • Handle all service names when parsing logs (#1129)
  • Reviewed and merged various community fixes (#1134, #1136, #1144)
Documentation
  • In the Ops docs: fixed the Jubilant module name in the opened ports example (#2844) and said that pebble.CheckInfo.level is UNSET when there’s no level (#2879).
  • Updated the Ops docs to match kubernetes and machine profile changes in Charmcraft 4.5. Also fixed several lingering issues in the Kubernetes and machine charm tutorials (#2889, #2890, #2893, #2904, #2907).
  • Moved the Hyrum documentation to canonical.com/juju/docs/hyrum.
  • Added How to set up production integrations (#2835).
  • Worked on a how-to manage proxy configs guide.
