In Charm Tech this pulse we’ve made a push on Quality of Life improvements across the various products we maintain. We’ve released updates to Hyrum, Pebble and Ops, with Ops requiring special attention due to a security fix. Please update to 3.8.3 or 3.9.0 to prevent leaking secrets into tracing span data.
Ops
- Released 3.8.3, which is a security fix to stop Ops sending the content of Juju secrets in tracing span data. Please update as soon as possible.
- Released 3.9.0 and 2.23.6, which are both collections of assorted bug fixes (3.9.0 includes the security fix from 3.8.3).
- Enforced relation databag read permissions on all access paths (#2738), and made a relation that has gone away raise
RelationNotFoundErrorrather than “permission denied” (#2748). - Kept sensitive data out of traces and hook command errors (#2782). Started work on avoiding exponential backtracking in the
ops.testingstorage name check (#2800). - Added an exception note when raising
ModelError(#2786). - Let charms and libraries set
onwithout atype: ignore(#2775). - In
ops.testing: treated an_Abort(0)from the charm’s__init__as success (#2780), and recorded trace data in every run with opentelemetry-sdk 1.45 (#2787). - Worked on making
ops.hookcmdsreturn all the data that the hook commands output (#2805).
Charming
- Added a Workshop dev environment across Charm Tech repos: Hyrum (#136) and pytest-jubilant (#123) merged, with Ops (#2801), Charmlint (#434), Jubilant (#432) and charm-ubuntu (#125) in progress.
- Added secrets handling to Charmcraft’s Kubernetes and machine init profiles (#2814).
- Worked on adding Jubilant logging of how long
waittook when it succeeds, fails, or times out (#419) - Worked on adding an
ssh_keyargument toJuju.sshandJuju.scpfor Juju 4.1 support (#430). - Drafted defaulting pytest-jubilant’s
--juju-dump-logsto thelog_filedirectory (#124). - Released Hyrum 1.0.0 (#169), including some additional improvements prior to that.
- Finalised upgrading
jhack scenario snapshotwith bug, linting and formatting fixes (#252). - Worked on adding a GitHub configuration to the kubernetes and machine Charmcraft profiles (#2921).
Charmlibs
- Worked on testing Charmlibs with Juju 4 (#707)
- Added provider and requirer charms for interface library integration tests (#698).
- Wrote OP093, which specifies how charm library testing packages can ship charm-shaped stand-ins for use with multiple-charm state-transition testing.
Pebble
- Released Pebble v1.33.0 and v1.33.0-fips.
- Fixed the setup of termios to pass input flags correctly (#1115).
- Reject invalid metric types for Pebble’s prometheus scrape end point (#1118).
- Fixed a panic in tlsstate (#1120).
- Progress: Tracing self-telemetry for Pebble (#1103 #1114).
- Progress: OP090 - Pebble TLS Trust Context spec accepted in principle.
- Progress: OP092 - Pebble scheduled service start spec accepted in principle.
- Drafting new specification OP095 - Pebble service starting check.
Documentation
- Two small bug fixes in the Ops docs: the ‘self-review’ command in the discoverability how-to (#2764) and mounting the project directory to a target relative to the home directory (#2765).
- Added initial documentation for Hyrum (#99).
- Described Concierge’s security model (#262).
- Added a mention of
jubilant-backportsfor Juju 2.9 support in the Jubilant docs (#421). - Posted a summary of how the Charming Survey 26.04 requests were reflected the work we did this cycle, and how the 26.10 responses have influenced the work we plan to do over the next six months.
- Added a how-to use Jubilant wait from CLI guide (#413).
