What has Charm Tech been busy with in pulse #20? We released Ops 2.17.0, worked on moving the state transition testing library (“Scenario”) into the Ops repo, built a working proof-of-concept to remove AllWatcher from python-libjuju, worked to bring python-libjuju code generation up to date, and added integration tests for pebble run.
The ops library
- Released ops 2.17.0, which includes first-class support for state transition testing (“Scenario”) via
pip install ops[testing], fixes for secret handling, and more. Read the release notes for details. And if you’re not familiar with Scenario / state transition testing, see the new docs page – we recommend this over Harness for new charm tests. - Produced an almost-complete PR that pulls the ops-scenario code into the Ops repo, to make code changes simpler and more consistent.
- Reworked
ops.main()type annotations to avoid requiringtype: ignoreon that call.
Charming
- Work-in-progress PR for python-libjuju to do live Juju RPC calls using separate events in a helper thread. This is part of the Great AllWatcher-ectomy of '24.
- Investigated flakey python-libjuju integration tests.
- Spent time cleaning up the python-libjuju schemas and code generation and bringing them up to date (work in progress).
- Added a
charmcraft analysechecker to ensure theops.main()call is present, and a tweak to use the newops.maintype hints incharmcraft inittemplates. - Adjusted the
charmcraft inittemplates to use state transition (Scenario) tests. - Spent some time brainstorming what we think the future of integration tests should look like.
Pebble
- Wrote a small suite of integration tests for
pebble run, and made the “root tests” easier to run.
