Hi
How to monitor the Charm OpenStack (Yoga / Focal). I have deployed HA OpenStack using MAAS/JUJU/Charm. I want to monitor the OpenStack services, API endpoints, CEPH, etc…
Is there any document available?
Hi
Hi pmatulis
The COS Lite is for Kubernetes platform. I am looking for OpenStack.
I want to monitor all OpenStack endpoints, VIP, CEPH cluster status,etc…
hi @rrajasekar, COS Lite is meant to be related to any charm that implements the correct relations, not just Kubernetes. Eventually, that’s going to include charmed OpenStack. As of today your only option is to use the legacy LMA charms:
Please keep in mind that the charms above are in maintenance mode while we transition to the COS Lite (and its future iterations) and that unfortunately we don’t really have an easy to apply overlay for setting up monitoring. The charm READMEs should however be sufficient to get you started. Good luck!
