Hi @hpidcock Thank you for interest
Hello @billy-olsen , here is the sample detail:
lxc list
To start your first container, try: lxc launch ubuntu:22.04
Or for a virtual machine: lxc launch ubuntu:22.04 --vm
| NAME | STATE | IPV4 | IPV6 | TYPE | SNAPSHOTS |
| juju-05c63e-0-lxd-3 | RUNNING | 11.0.12.216 (eth0) | | CONTAINER | 0 |
For the log in juju ssh 0 (/var/log/juju/machine-0.log) on the attachement(new user cant log attachment):
2023-07-05 06:00:36 INFO juju.worker.lxdprovisioner provisioner_task.go:1486 started machine 0/lxd/2 as instance juju-05c63e-0-lxd-2 with hardware “availability-zone=default”, network config [], volumes [], volume attachments map[], subnets to zones [], lxd profiles []
2023-07-05 06:00:36 INFO juju.worker.instancemutater.container mutater.go:245 no changes necessary to machine-0/lxd/2 lxd profiles ([default])
2023-07-05 06:22:52 INFO juju.worker.diskmanager diskmanager.go:67 block devices changed: []storage.BlockDevice{storage.BlockDevice{DeviceName:“loop0”, DeviceLinks:[]string(nil), Label:"", UUID:"", HardwareId:"", WWN:"", BusAddress:"", Size:0x3f, FilesystemType:“squashfs”, InUse:true, MountPoint:"/snap/core20/1852", SerialId:""}, storage.BlockDevice{DeviceName:“loop1”, DeviceLinks:[]string(nil), Label:"", UUID:"", HardwareId:"", WWN:"", BusAddress:"", Size:0x6f, FilesystemType:“squashfs”, InUse:true, MountPoint:"/snap/lxd/24322", SerialId:""}, storage.BlockDevice{DeviceName:“loop2”, DeviceLinks:[]string(nil), Label:"", UUID:"", HardwareId:"", WWN:"", BusAddress:"", Size:0x31, FilesystemType:“squashfs”, InUse:true, MountPoint:"/snap/snapd/18596", SerialId:""}, storage.BlockDevice{DeviceName:“loop3”, DeviceLinks:[]string(nil), Label:"", UUID:"", HardwareId:"", WWN:"", BusAddress:"", Size:0x35, FilesystemType:“squashfs”, InUse:true, MountPoint:"/snap/snapd/19457", SerialId:""}, storage.BlockDevice{DeviceName:“sda”, DeviceLinks:[]string{"/dev/disk/by-path/pci-0000:00:10.0-scsi-0:0:0:0"}, Label:"", UUID:"", HardwareId:"", WWN:"", BusAddress:“scsi@32:0.0.0”, Size:0x28000, FilesystemType:"", InUse:true, MountPoint:"", SerialId:""}, storage.BlockDevice{DeviceName:“sda1”, DeviceLinks:[]string{"/dev/disk/by-partuuid/d39c27e7-5af7-4810-9487-02a388b3936e", “/dev/disk/by-path/pci-0000:00:10.0-scsi-0:0:0:0-part1”}, Label:"", UUID:"", HardwareId:"", WWN:"", BusAddress:“scsi@32:0.0.0”, Size:0x1, FilesystemType:"", InUse:false, MountPoint:"", SerialId:""}, storage.BlockDevice{DeviceName:“sda2”, DeviceLinks:[]string{"/dev/disk/by-dname/sda-part2", “/dev/disk/by-label/root”, “/dev/disk/by-partuuid/f1f054a5-6cd6-4fec-a8ae-c0df28d62621”, “/dev/disk/by-path/pci-0000:00:10.0-scsi-0:0:0:0-part2”, “/dev/disk/by-uuid/2bf8149b-e17c-490b-905e-1458a0e83f3b”}, Label:“root”, UUID:“2bf8149b-e17c-490b-905e-1458a0e83f3b”, HardwareId:"", WWN:"", BusAddress:“scsi@32:0.0.0”, Size:0x27ffd, FilesystemType:“ext4”, InUse:true, MountPoint:"/", SerialId:""}, storage.BlockDevice{DeviceName:“sdb”, DeviceLinks:[]string{"/dev/disk/by-path/pci-0000:00:10.0-scsi-0:0:1:0"}, Label:"", UUID:"", HardwareId:"", WWN:"", BusAddress:“scsi@32:0.1.0”, Size:0x19000, FilesystemType:"", InUse:false, MountPoint:"", SerialId:""}}
2023-07-05 06:24:22 INFO juju.worker.diskmanager diskmanager.go:67 block devices changed: []storage.BlockDevice{storage.BlockDevice{DeviceName:“loop0”, DeviceLinks:[]string(nil), Label:"", UUID:"", HardwareId:"", WWN:"", BusAddress:"", Size:0x3f, FilesystemType:“squashfs”, InUse:true, MountPoint:"/snap/core20/1852", SerialId:""}, storage.BlockDevice{DeviceName:“loop1”, DeviceLinks:[]string(nil), Label:"", UUID:"", HardwareId:"", WWN:"", BusAddress:"", Size:0x6f, FilesystemType:“squashfs”, InUse:true, MountPoint:"/snap/lxd/24322", SerialId:""}, storage.BlockDevice{DeviceName:“loop2”, DeviceLinks:[]string(nil), Label:"", UUID:"", HardwareId:"", WWN:"", BusAddress:"", Size:0x31, FilesystemType:“squashfs”, InUse:true, MountPoint:"/snap/snapd/18596", SerialId:""}, storage.BlockDevice{DeviceName:“loop3”, DeviceLinks:[]string(nil), Label:"", UUID:"", HardwareId:"", WWN:"", BusAddress:"", Size:0x35, FilesystemType:“squashfs”, InUse:true, MountPoint:"/snap/snapd/19457", SerialId:""}, storage.BlockDevice{DeviceName:“loop4”, DeviceLinks:[]string(nil), Label:"", UUID:"", HardwareId:"", WWN:"", BusAddress:"", Size:0x3f, FilesystemType:“squashfs”, InUse:true, MountPoint:"/snap/core20/1974", SerialId:""}, storage.BlockDevice{DeviceName:“sda”, DeviceLinks:[]string{"/dev/disk/by-path/pci-0000:00:10.0-scsi-0:0:0:0"}, Label:"", UUID:"", HardwareId:"", WWN:"", BusAddress:“scsi@32:0.0.0”, Size:0x28000, FilesystemType:"", InUse:true, MountPoint:"", SerialId:""}, storage.BlockDevice{DeviceName:“sda1”, DeviceLinks:[]string{"/dev/disk/by-partuuid/d39c27e7-5af7-4810-9487-02a388b3936e", “/dev/disk/by-path/pci-0000:00:10.0-scsi-0:0:0:0-part1”}, Label:"", UUID:"", HardwareId:"", WWN:"", BusAddress:“scsi@32:0.0.0”, Size:0x1, FilesystemType:"", InUse:false, MountPoint:"", SerialId:""}, storage.BlockDevice{DeviceName:“sda2”, DeviceLinks:[]string{"/dev/disk/by-dname/sda-part2", “/dev/disk/by-label/root”, “/dev/disk/by-partuuid/f1f054a5-6cd6-4fec-a8ae-c0df28d62621”, “/dev/disk/by-path/pci-0000:00:10.0-scsi-0:0:0:0-part2”, “/dev/disk/by-uuid/2bf8149b-e17c-490b-905e-1458a0e83f3b”}, Label:“root”, UUID:“2bf8149b-e17c-490b-905e-1458a0e83f3b”, HardwareId:"", WWN:"", BusAddress:“scsi@32:0.0.0”, Size:0x27ffd, FilesystemType:“ext4”, InUse:true, MountPoint:"/", SerialId:""}, storage.BlockDevice{DeviceName:“sdb”, DeviceLinks:[]string{"/dev/disk/by-path/pci-0000:00:10.0-scsi-0:0:1:0"}, Label:"", UUID:"", HardwareId:"", WWN:"", BusAddress:“scsi@32:0.1.0”, Size:0x19000, FilesystemType:"", InUse:false, MountPoint:"", SerialId:""}}
2023-07-05 06:41:27 INFO juju.worker.lxdprovisioner provisioner_task.go:629 stopping known instances [juju-05c63e-0-lxd-2]
2023-07-05 06:41:27 INFO juju.container.broker.lxd lxd-broker.go:142 stopping lxd container for instance: juju-05c63e-0-lxd-2
2023-07-05 06:41:30 INFO juju.container.broker.lxd broker.go:146 released all addresses for container “0/lxd/2”
2023-07-05 06:41:30 INFO juju.worker.lxdprovisioner provisioner_task.go:645 removing dead machine “0/lxd/2”
2023-07-05 06:43:22 INFO juju.worker.lxdprovisioner provisioner_task.go:504 found machine pending provisioning id:0/lxd/3, details:0/lxd/3
2023-07-05 06:43:25 WARNING juju.container.broker broker.go:76 no search domains supplied by provider, using host’s search domains.
2023-07-05 06:43:25 WARNING juju.container.broker broker.go:84 incomplete DNS config found, discovering host’s DNS config
2023-07-05 06:43:25 INFO juju.cloudconfig userdatacfg_unix.go:613 Fetching agent: curl -sSf --connect-timeout 20 --noproxy “*” --insecure -o $bin/tools.tar.gz <[https://11.0.12.201:17070/model/8e869d67-0a1f-4fde-8778-added705c63e/tools/2.9.43-ubuntu-amd64]>
2023-07-05 06:43:25 INFO juju.container.lxd container.go:256 starting new container “juju-05c63e-0-lxd-3” (image “ubuntu-22.04-server-cloudimg-amd64-lxd.tar.xz”)
2023-07-05 06:43:40 INFO juju.worker.lxdprovisioner provisioner_task.go:1486 started machine 0/lxd/3 as instance juju-05c63e-0-lxd-3 with hardware “availability-zone=default”, network config [], volumes [], volume attachments map[], subnets to zones [], lxd profiles []
2023-07-05 06:43:41 INFO juju.worker.instancemutater.container mutater.go:245 no changes necessary to machine-0/lxd/3 lxd profiles ([default])
2023-07-09 15:00:58 INFO juju.cmd supercommand.go:56 running jujud [2.9.43 3cb3f8beac4a0b05e10bdfb8014f5666118a269d gc go1.20.4]
2023-07-09 15:00:58 DEBUG juju.cmd supercommand.go:57 args: []string{"/var/lib/juju/tools/machine-0/jujud", “machine”, “–data-dir”, “/var/lib/juju”, “–machine-id”, “0”, “–debug”}
2023-07-09 15:00:58 DEBUG juju.utils gomaxprocs.go:24 setting GOMAXPROCS to 4
2023-07-09 15:00:58 DEBUG juju.agent agent.go:603 read agent config, format “2.0”
2023-07-09 15:00:58 INFO juju.agent.setup agentconf.go:128 setting logging config to “=INFO”
2023-07-09 15:00:58 INFO juju.worker.upgradesteps worker.go:60 upgrade steps for 2.9.43 have already been run.
2023-07-09 15:00:58 INFO juju.api apiclient.go:687 connection established to “wss://11.0.12.201:17070/model/8e869d67-0a1f-4fde-8778-added705c63e/api”
2023-07-09 15:00:58 INFO juju.worker.apicaller connect.go:163 [8e869d] “machine-0” successfully connected to “11.0.12.201:17070”
2023-07-09 15:00:58 INFO juju.worker.upgrader upgrader.go:241 desired agent binary version: 2.9.43
2023-07-09 15:00:58 INFO juju.worker.deployer nested.go:159 new context: units “ceph-osd/0”, stopped “”
2023-07-09 15:00:59 INFO juju.worker.deployer unit_agent.go:125 creating new agent config for “ceph-osd/0”
2023-07-09 15:00:59 INFO juju.worker.deployer nested.go:366 starting workers for “ceph-osd/0”
2023-07-09 15:00:59 INFO juju.worker.deployer deployer.go:161 checking unit “ceph-osd/0”
2023-07-09 15:00:59 INFO juju.worker.migrationminion worker.go:142 migration phase is now: NONE
2023-07-09 15:00:59 INFO juju.worker.logger logger.go:120 logger worker started
2023-07-09 15:00:59 INFO juju.api apiclient.go:687 connection established to “wss://11.0.12.201:17070/model/8e869d67-0a1f-4fde-8778-added705c63e/api”
2023-07-09 15:00:59 INFO juju.worker.upgradeseries worker.go:162 no series upgrade lock present
2023-07-09 15:00:59 INFO juju.worker.machiner machiner.go:163 setting addresses for “machine-0” to [local-machine:127.0.0.1 public:11.0.12.202 local-machine:::1]
2023-07-09 15:00:59 INFO juju.packaging.manager run.go:88 Running: snap info lxd
2023-07-09 15:00:59 INFO juju.worker.machiner machiner.go:113 “machine-0” started
2023-07-09 15:00:59 INFO juju.worker.leadership tracker.go:217 ceph-osd leadership for ceph-osd/0 denied
2023-07-09 15:00:59 INFO juju.worker.authenticationworker worker.go:101 “machine-0” key updater worker started
2023-07-09 15:00:59 INFO juju.agent.tools symlinks.go:20 ensure jujuc symlinks in /var/lib/juju/tools/unit-ceph-osd-0
2023-07-09 15:00:59 INFO juju.agent.tools symlinks.go:40 was a symlink, now looking at /var/lib/juju/tools/2.9.43-ubuntu-amd64
2023-07-09 15:00:59 INFO juju.worker.diskmanager diskmanager.go:67 block devices changed: []storage.BlockDevice{storage.BlockDevice{DeviceName:“loop0”, DeviceLinks:[]string(nil), Label:"", UUID:"", HardwareId:"", WWN:"", BusAddress:"", Size:0x3f, FilesystemType:“squashfs”, InUse:true, MountPoint:"/snap/core20/1974", SerialId:""}, storage.BlockDevice{DeviceName:“loop1”, DeviceLinks:[]string(nil), Label:"", UUID:"", HardwareId:"", WWN:"", BusAddress:"", Size:0x3f, FilesystemType:“squashfs”, InUse:true, MountPoint:"/snap/core20/1852", SerialId:""}, storage.BlockDevice{DeviceName:“loop2”, DeviceLinks:[]string(nil), Label:"", UUID:"", HardwareId:"", WWN:"", BusAddress:"", Size:0x6f, FilesystemType:“squashfs”, InUse:true, MountPoint:"/snap/lxd/24322", SerialId:""}, storage.BlockDevice{DeviceName:“loop3”, DeviceLinks:[]string(nil), Label:"", UUID:"", HardwareId:"", WWN:"", BusAddress:"", Size:0x31, FilesystemType:“squashfs”, InUse:true, MountPoint:"/snap/snapd/18596", SerialId:""}, storage.BlockDevice{DeviceName:“loop4”, DeviceLinks:[]string(nil), Label:"", UUID:"", HardwareId:"", WWN:"", BusAddress:"", Size:0x35, FilesystemType:“squashfs”, InUse:true, MountPoint:"/snap/snapd/19457", SerialId:""}, storage.BlockDevice{DeviceName:“sda”, DeviceLinks:[]string{"/dev/disk/by-path/pci-0000:00:10.0-scsi-0:0:0:0"}, Label:"", UUID:"", HardwareId:"", WWN:"", BusAddress:“scsi@32:0.0.0”, Size:0x28000, FilesystemType:"", InUse:true, MountPoint:"", SerialId:""}, storage.BlockDevice{DeviceName:“sda1”, DeviceLinks:[]string{"/dev/disk/by-partuuid/d39c27e7-5af7-4810-9487-02a388b3936e", “/dev/disk/by-path/pci-0000:00:10.0-scsi-0:0:0:0-part1”}, Label:"", UUID:"", HardwareId:"", WWN:"", BusAddress:“scsi@32:0.0.0”, Size:0x1, FilesystemType:"", InUse:false, MountPoint:"", SerialId:""}, storage.BlockDevice{DeviceName:“sda2”, DeviceLinks:[]string{"/dev/disk/by-dname/sda-part2", “/dev/disk/by-label/root”, “/dev/disk/by-partuuid/f1f054a5-6cd6-4fec-a8ae-c0df28d62621”, “/dev/disk/by-path/pci-0000:00:10.0-scsi-0:0:0:0-part2”, “/dev/disk/by-uuid/2bf8149b-e17c-490b-905e-1458a0e83f3b”}, Label:“root”, UUID:“2bf8149b-e17c-490b-905e-1458a0e83f3b”, HardwareId:"", WWN:"", BusAddress:“scsi@32:0.0.0”, Size:0x27ffd, FilesystemType:“ext4”, InUse:true, MountPoint:"/", SerialId:""}, storage.BlockDevice{DeviceName:“sdb”, DeviceLinks:[]string{"/dev/disk/by-path/pci-0000:00:10.0-scsi-0:0:1:0"}, Label:"", UUID:"", HardwareId:"", WWN:"", BusAddress:“scsi@32:0.1.0”, Size:0x19000, FilesystemType:"", InUse:false, MountPoint:"", SerialId:""}}
2023-07-09 15:01:01 INFO juju.container.lxd initialisation_linux.go:295 LXD snap is already installed (channel: 5.0/stable/ubuntu-22.04); skipping package installation
2023-07-09 15:01:10 INFO juju.worker.instancemutater.container mutater.go:245 no changes necessary to machine-0/lxd/3 lxd profiles ([default])
2023-07-09 15:01:11 INFO juju.worker.instancemutater.container mutater.go:245 no changes necessary to machine-0/lxd/3 lxd profiles ([default])
2023-07-09 15:01:13 INFO juju.worker.lxdprovisioner provisioner_task.go:203 entering provisioner task loop; using provisioner pool with 4 workers
2023-07-09 15:01:13 INFO juju.worker.lxdprovisioner provisioner_task.go:518 machine 0/lxd/3 already started as instance “juju-05c63e-0-lxd-3”
Thank you for the support discussion
