Change Ownership of SD-Core K8s charms
Hello,
Please change the ownership of the below charms and bundles to the "Canonical Telco” team.
Thanks!
  • sdcore-amf-k8s
  • sdcore-ausf-k8s
  • sdcore-nrf-k8s
  • sdcore-nssf-k8s
  • sdcore-pcf-k8s
  • sdcore-smf-k8s
  • sdcore-udm-k8s
  • sdcore-udr-k8s
  • sdcore-upf-k8s
  • sdcore-gnbsim-k8s
  • sdcore-router-k8s
  • sdcore-webui-k8s
  • sdcore-nms-k8s
  • sdcore-control-plane-k8s
  • sdcore-user-plane-k8s
  • sdcore-k8s
Hi,
These are all done except for the last two. It appears you haven’t released anything for these two yet?
Thanks,
Odysseus
Hello @odysseus-k ,
I made a mistake by registering bundles. The following names should be used for bundles but I registered them like charm. Could you please help me to delete them in charmhub and I can register them as bundles.
Many thanks!
  • sdcore-k8s
I need to use the following names to register bundles but not charms. If it deletion is not possible, could we change the type from charm to bundle ?
charmcraft register-bundle sdcore-control-plane-k8s Store operation failed:
* already-registered: Name 'sdcore-control-plane-k8s' is already registered
Full execution log: '/home/gatici/.local/state/charmcraft/log/charmcraft-20231208-173450.419081.log'
Unregister command solved the problem.
$ charmcraft unregister sdcore-control-plane-k8s Name ‘sdcore-control-plane-k8s’ has been removed from Charmhub.
$ charmcraft register-bundle sdcore-control-plane-k8s You are now the publisher of bundle ‘sdcore-control-plane-k8s’ in Charmhub.
