Change default track to 1.23/stable for all Temporal Charms
Hi Team,
I’d like to change the default track for all Temporal Charms from latest/stable to 1.23/stable. The following charm tracks are to be updated:
Charms
(default track: 1.23/stable)
  1. temporal-k8s
  2. temporal-ui-k8s
  3. temporal-admin-k8s
(default track: 1.0/stable)
  1. temporal-worker-k8s
Thank You!
Hi,
The tracks have been created and assigned as default for the temporal charms.
Thank you Colin. Can you also default the base to 24.04 for all charms?
  1. temporal-k8s
  2. temporal-ui-k8s
  4. temporal-worker-k8s
Default bases can be set for individual charms from the client side by either setting the default-base for the model config of specifying the base when downloading by using the –base flag.
I.e
juju config-model default-base=ubuntu@24.04 or juju download --channel 1.23/stable --base ubuntu@24.04
If neither of these are set then charmhub will default to the latest LTS version that is available for the charm on the channel being downloaded.
