Change default track of Charmed-etcd
Hi there,
Could you set the `3.6/` track of charmed-etcd as the default branch?
Thanks,
Mehdi
Hi,
I’ve set 3.6 as the default track for charmed-etcd.
I don’t think it’s showing up in search/find yet, so could you please try re-releasing the charm to 3.6/stable using charmcraft release? It should hopefully show up after that.
Thanks,
Deep
Thank you @superalpaca !
