Hello, can you please change the following charm name in charmhub from tls-certificates-operator
to manual-tls-certificates
We will also change the appropriate charm’s metadata to reflect this in this PR:
Hi,
Charms cannot be renamed but their charmhub page title can be updated by changing the display-name
field in metadata.yaml
, if that will not work for you an alternative is to register manual-tls-certificates-operator name and push new revisions there.
Thanks,
Haa ok @mthaddon I was under the impression that we could rename charms. If not, we’ll go ahead with registering the new charm name.
Hi,
He is not wrong in that it was done once, by @roadmr and that knowledge is now lost
There is no API support for this, and we would need to go into updating the DB directly, which honestly don’t know which side-effect it might trigger.
Cheers,
