Overview
Ceph is a unified, distributed storage system designed for excellent performance, reliability, and scalability.
The ceph-osd charm deploys the Ceph object storage daemon (OSD) and manages its volumes. It is used in conjunction with the ceph-mon charm. Together, these charms can scale out the amount of storage available in a Ceph cluster.
Important: This documentation supports version 3.x of the Juju client.
See the OpenStack Charm
guide if you are using the 2.9.x client.
Usage
Configuration
This section covers common and/or important configuration options. See file
config.yaml for the full list of options, along with their descriptions and
default values. A YAML file (e.g. ceph-osd.yaml) is often used to store
configuration options. See the Juju documentation for
details on configuring applications.
bluestore
The bluestore option specifies whether the
BlueStore storage backend is used for all OSD
devices. The feature is enabled by default (value âTrueâ). If set to âTrueâ,
this option overrides the osd-format option as BlueStore does not use a
traditional filesystem.
Important: This option has no effect unless Ceph Luminous (or greater) is in use.
customize-failure-domain
The customize-failure-domain option determines how a Ceph CRUSH map is
configured.
A value of âfalseâ (the default) will lead to a map that will replicate data across hosts (implemented as Ceph bucket type âhostâ). With a value of âtrueâ all MAAS-defined zones will be used to generate a map that will replicate data across Ceph availability zones (implemented as bucket type ârackâ).
This option is also supported by the ceph-mon charm. Its value must be the same for both charms.
osd-devices
The osd-devices option lists what block devices can be used for OSDs across
the cluster. See section âStorage devicesâ for an elaboration on this
fundamental topic.
osd-format
The osd-format option specifies what filesystem to use for all OSD devices
(âxfsâ or âext4â). The default value is âxfsâ. This option only applies when
Ceph Luminous (or greater) is in use and option bluestore is set to âFalseâ.
source
The source option states the software sources. A common value is an OpenStack
UCA release (e.g. âcloud:xenial-queensâ or âcloud:bionic-ussuriâ). See Ceph
and the UCA. The underlying hostâs existing apt sources
will be used if this option is not specified (this behaviour can be explicitly
chosen by using the value of âdistroâ).
Storage devices
A storage device is destined as an OSD (Object Storage Device). There can be multiple OSDs per storage node (ceph-osd unit).
The list of all possible storage devices for the cluster is defined by the
osd-devices option. The below examples can be used in the ceph-osd.yaml
configuration file.
Block devices (regular),
ceph-osd:
osd-devices: /dev/vdb /dev/vdc /dev/vdd
Each regular block device must be an absolute path to a device node.
Block devices (Juju storage),
ceph-osd:
storage:
osd-devices: cinder,20G
See the Juju documentation for guidance on implementing Juju storage.
Directory-backed OSDs,
ceph-osd:
storage:
osd-devices: /var/tmp/osd-1
Note: OSD directories can no longer be created starting with Ceph Nautilus. Existing OSD directories will continue to function after an upgrade to Nautilus.
The list defined by option osd-devices may affect newly added ceph-osd units
as well as existing units (the option may be modified after units have been
added). The charm will attempt to activate as Ceph storage any listed device
that is visible by the unitâs underlying machine. To prevent the activation of
volumes on existing units the blacklist-add-disk action may be used.
The configuration option is modified in the usual way. For instance, to have it consist solely of devices â/dev/sdbâ and â/dev/sdcâ:
juju config ceph-osd osd-devices='/dev/sdb /dev/sdc'
The charm will go into a blocked state (visible in juju status output) if it
detects pre-existing data on a device. In this case the operator can either
instruct the charm to ignore the disk (action blacklist-add-disk) or to have
it purge all data on the disk (action zap-disk).
Important: The recommended minimum number of OSDs in the cluster is three and this is what the ceph-mon charm expects (the cluster will not form with a lesser number). See option
expected-osd-countin the ceph-mon charm to overcome this but beware that going below three is not a supported configuration.
Deployment
A cloud with three MON nodes is a typical design whereas three OSDs are considered the minimum. For example, to deploy a Ceph cluster consisting of three OSDs (one per ceph-osd unit) and three MONs:
juju deploy -n 3 --config ceph-osd.yaml ceph-osd
juju deploy -n 3 --to lxd:0,lxd:1,lxd:2 ceph-mon
juju integrate ceph-osd:mon ceph-mon:osd
Here, a containerised MON is running alongside each storage node. Weâve assumed that the machines spawned in the first command are assigned IDs of 0, 1, and 2.
Note: Refer to the Install OpenStack page in the OpenStack Charms Deployment Guide for instructions on installing the ceph-osd application for use with OpenStack.
For each ceph-osd unit, the ceph-osd charm will scan for all the devices
configured via the osd-devices option and attempt to assign to it all of the
ones it finds. The clusterâs initial pool of available storage is the âsumâ of
all these assigned devices.
Network spaces
This charm supports the use of Juju network spaces (Juju
v.2.0). This feature optionally allows specific types of the applicationâs
network traffic to be bound to subnets that the underlying hardware is
connected to.
Note: Spaces must be configured in the backing cloud prior to deployment.
The ceph-osd charm exposes the following Ceph traffic types (bindings):
- âpublicâ (front-side)
- âclusterâ (back-side)
For example, providing that spaces âdata-spaceâ and âcluster-spaceâ exist, the deploy command above could look like this:
juju deploy --config ceph-osd.yaml -n 3 ceph-osd \
--bind "public=data-space cluster=cluster-space"
Alternatively, configuration can be provided as part of a bundle:
ceph-osd:
charm: cs:ceph-osd
num_units: 1
bindings:
public: data-space
cluster: cluster-space
Refer to the Ceph Network Reference to learn about the implications of segregating Ceph network traffic.
Note: Existing ceph-osd units configured with the
ceph-public-networkorceph-cluster-networkoptions will continue to honour them. Furthermore, these options override any space bindings, if set.
AppArmor profiles
Although AppArmor is not enabled for Ceph by default, an AppArmor profile can
be generated by the charm by assigning a value of âcomplainâ, âenforceâ, or
âdisableâ (the default) to option aa-profile-mode.
Caution: Enabling an AppArmor profile is disruptive to a running Ceph cluster as all ceph-osd processes must be restarted.
The new profile has a narrow supported use case, and it should always be verified in pre-production against the specific configurations and topologies intended for production.
The profiles generated by the charm should not be used in the following scenarios:
- On any version of Ubuntu older than 16.04
- On any version of Ceph older than Luminous
- When OSD journal devices are in use
- When Ceph BlueStore is enabled
Block device encryption
The ceph-osd charm supports encryption for OSD volumes that are backed by block
devices. To use Cephâs native key management framework, available since Ceph
Jewel, set option osd-encrypt for the ceph-osd charm:
ceph-osd:
osd-encrypt: True
Here, dm-crypt keys are stored in the MON sub-cluster.
Alternatively, since Ceph Luminous, encryption keys can be stored in Vault,
which is deployed and initialised via the vault charm. Set
options osd-encrypt and osd-encrypt-keymanager for the ceph-osd charm:
ceph-osd:
osd-encrypt: True
osd-encrypt-keymanager: vault
Important: Post deployment configuration will only affect block devices associated with new ceph-osd units.
Actions
This section covers Juju actions supported by the charm.
Actions allow specific operations to be performed on a per-unit basis. To
display action descriptions run juju actions --schema ceph-osd. If the charm
is not deployed then see file actions.yaml.
add-diskblacklist-add-diskblacklist-remove-diskget-availibility-zonelist-disksosd-inosd-outsecurity-checkliststartstopzap-disk
Working with OSDs
Set OSDs to âoutâ
Use the osd-out action to set OSD volumes on a unit to âoutâ.
Warning: This action has the potential of impacting your cluster significantly. The Ceph documentation on this topic is considered essential reading.
Unless the cluster itself is set to ânooutâ this action will cause Ceph to rebalance data by migrating PGs out of the affected OSDs and onto OSDs available on other units. The impact is twofold:
- The available space on the remaining OSDs is reduced. Not only is there less space for future workloads but there is a danger of exceeding the clusterâs storage capacity.
- The traffic and CPU load on the cluster is increased.
Note: It has been reported that setting OSDs to âoutâ may cause some PGs to get stuck in the âactive+remappedâ state. This is an upstream issue.
The ceph-mon charm has an action called set-noout that sets
ânooutâ for the cluster.
It may be perfectly fine to have data rebalanced. The decisive factor is whether the OSDs are being paused temporarily (e.g. the underlying machine is scheduled for maintenance) or whether they are being removed from the cluster completely (e.g. the storage hardware is reaching EOL).
Examples:
# Set OSDs '0' and '1' to 'out' on unit `ceph-osd/4`
juju run --wait ceph-osd/4 osd-out osds=osd.0,osd.1
# Set all OSDs to 'out' on unit `ceph-osd/2`
juju run --wait ceph-osd/2 osd-out osds=all
Set OSDs to âinâ
Use the osd-in action to set OSD volumes on a unit to âinâ.
The osd-in action is reciprocal to the osd-out action. The OSDs are set to
âinâ. It is typically used when the osd-out action was used in conjunction
with the cluster ânooutâ flag.
Examples:
# Set OSDs '0' and '1' to 'in' on unit `ceph-osd/4`
juju run --wait ceph-osd/4 osd-in osds=osd.0,osd.1
# Set all OSDs to 'in' on unit `ceph-osd/2`
juju run --wait ceph-osd/2 osd-in osds=all
Stop and start OSDs
Use the stop and start actions to stop and start OSD daemons on a unit.
Important: These actions are not available on the âtrustyâ series due to the reliance on
systemd.
Examples:
# Stop services 'ceph-osd@0' and 'ceph-osd@1' on unit `ceph-osd/4`
juju run --wait ceph-osd/4 stop osds=0,1
# Start all ceph-osd services on unit `ceph-osd/2`
juju run --wait ceph-osd/2 start osds=all
Note: Stopping an OSD daemon will put the associated unit into a blocked state.
Working with disks
List disks
Use the list-disks action to list disks known to a unit.
The action lists the unitâs block devices by categorising them in three ways:
disks: visible (known by udev), unused (not mounted), and not designated as an OSD journal (via theosd-journalconfiguration option) -
blacklist: likedisksbut blacklisted (see actionblacklist-add-disk) -
non-pristine: likedisksbut not eligible for use due to the presence of existing data
Example:
# List disks on unit `ceph-osd/4`
juju run --wait ceph-osd/4 list-disks
Add a disk
Use the add-disk action to add a disk to a unit.
A ceph-osd unit is automatically assigned OSD volumes based on the current
value of the osd-devices application option. The add-disk action allows the
operator to manually add OSD volumes (for disks that are not listed by
osd-devices) to an existing unit.
Parameters
osd-devices(required)
A space-separated list of devices to format and initialise as OSD volumes.
bucket
The name of a Ceph bucket to add these devices to.
Example:
# Add disk /dev/vde on unit `ceph-osd/4`
juju run --wait ceph-osd/4 add-disk osd-devices=/dev/vde
Blacklist a disk
Use the blacklist-add-disk action to add a disk to a unitâs blacklist.
The action allows the operator to add disks (that are visible to the unitâs
underlying machine) to the unitâs blacklist. A blacklisted device will not be
initialised as an OSD volume when the value of the osd-devices application
option changes. This action does not prevent a device from being activated via
the add-disk action.
Use the list-disks action to list the unitâs blacklist entries.
Important: This action and blacklist do not have any effect on current OSD volumes.
Parameters
A space-separated list of devices to add to a unitâs blacklist.
Example:
# Blacklist disks /dev/vda and /dev/vdf on unit `ceph-osd/0`
juju run --wait ceph-osd/0 \
blacklist-add-disk osd-devices='/dev/vda /dev/vdf'
Un-blacklist a disk
Use the blacklist-remove-disk action to remove a disk from a unitâs
blacklist.
Parameters
A space-separated list of devices to remove from a unitâs blacklist.
Each device should have an existing entry in the unitâs blacklist. Use the
Example:
# Un-blacklist disk /dev/vdb on unit `ceph-osd/1`
juju run --wait ceph-osd/1 \
blacklist-remove-disk osd-devices=/dev/vdb
Zap a disk
Use the zap-disk action to purge a disk of all data.
In order to prevent unintentional data loss, the charm will not use a disk that
contains data. To forcibly make a disk available, the zap-disk action can be
used. Due to the destructive nature of this action the i-really-mean-it
option must be passed. This action is normally followed by the add-disk
action.
Parameters
devices(required)
A space-separated list of devices to be recycled.
i-really-mean-it(required)
A boolean option for confirming the action.
Example:
# Zap disk /dev/vdc on unit `ceph-osd/3`
juju run --wait ceph-osd/3 \
zap-disk i-really-mean-it=true devices=/dev/vdc
Note: The
zap-diskaction cannot be run on a mounted device, an active BlueStore device, or an encrypted device. There are also issues with LVM-backed volumes (see LP #1858519).
Documentation
The OpenStack Charms project maintains two documentation guides:
- OpenStack Charm Guide: for project information, including development and support notes
- OpenStack Charms Deployment Guide: for charm usage information
See also the Charmed Ceph documentation.
Bugs
Please report bugs on Launchpad.
Navigation
| Level | Path | Navlink |
| 1 | Home |
