A Report on metrics exported by Native Ceph-Exporter and default Alerts which use them. This report is divided into 2 major sections, 1. Metrics and 2. Alerts.
Section 1: Metrics
The native ceph exporter provides prometheus to scrape hundreds of metrics by default. However, not all of them are of operational importance for someone monitoring the Ceph Deployment. Thus this report contains a limited set of metrics which get used for defining the default set of Alerts. Every metric has a name, a condensed description, a type (of the quantity it represents), and labels. Labels add dimensionality to the otherwise single-dimensional time series.
1. ceph_health_detail:
healthcheck status by type (0=inactive, 1=active). Metric type gauge.
Used by following alerts
CephMonDownQuorumAtRisk, CephMonDiskspaceCritical, CephMonDiskspaceLow, CephMonClockSkew, CephOSDHostDown, CephOSDDown, CephOSDNearFull, CephOSDFull, CephOSDBackfillFull, CephOSDTooManyRepairs, CephOSDTimeoutsPublicNetwork, CephOSDTimeoutsClusterNetwork, CephOSDInternalDiskSizeMismatch, CephDeviceFailurePredicted, CephDeviceFailurePredictionTooHigh, CephDeviceFailureRelocationIncomplete, CephOSDReadErrors, CephFilesystemDamaged, CephFilesystemOffline, CephFilesystemDegraded, CephFilesystemMDSRanksLow, CephFilesystemInsufficientStandby, CephFilesystemFailureNoStandby, CephFilesystemReadOnly, CephMgrModuleCrash, CephPGsDamaged, CephPGRecoveryAtRisk, CephPGUnavilableBlockingIO, CephPGBackfillAtRisk, CephPGNotScrubbed, CephPGsHighPerOSD, CephPGNotDeepScrubbed, CephPoolBackfillFull, CephPoolFull, CephPoolNearFull, CephadmUpgradeFailed, CephadmDaemonFailed, CephadmPaused, CephObjectMissing, and CephObjectMissing
2. ceph_pg_active:
PG active per pool. Metric type gauge.
sample
ceph_pg_active{pool_id=“1”} 128.0
3. ceph_osd_numpg:
Placement groups. Metric type gauge.
sample
ceph_osd_numpg{ceph_daemon=“osd.1”} 161.0
4. ceph_osd_up:
OSD status up. Metric type untyped.
CephOSDDownHigh, CephOSDFlapping, and CephOSDFlapping
sample
ceph_osd_up{ceph_daemon=“osd.0”} 1.0
5. ceph_pg_total:
PG Total Count per Pool. Metric type gauge.
CephPGsInactive, and CephPGsInactive
sample
ceph_pg_total{pool_id=“1”} 128.0
6. ceph_healthcheck_slow_ops:
OSD or Monitor requests taking a long time to process. Metric type gauge.
sample
ceph_healthcheck_slow_ops 0.0
7. ceph_pool_percent_used:
DF pool percent_used. Metric type gauge.
sample
ceph_pool_percent_used{pool_id=“1”} 0.0
8. ceph_pool_metadata:
POOL Metadata. Metric type untyped.
CephPGsInactive, CephPGsUnclean, and CephPGsUnclean
sample
ceph_pool_metadata{pool_id=“1”,name=“default.rgw.buckets.data”,type=“replicated”,description=“replica:3”,compression_mode=“none”} 1.0
9. ceph_osd_metadata:
OSD Metadata. Metric type untyped.
CephOSDFlapping, CephPGImbalance, and CephPGImbalance
sample
ceph_osd_metadata{back_iface="",ceph_daemon=“osd.0”,cluster_addr=“10.5.2.89”,device_class=“hdd”,front_iface="",hostname=“juju-080297-zaza-5e7b19357667-5”,objectstore=“bluestore”,public_addr=“10.5.2.89”,ceph_version=“ceph version 17.2.0 (43e2e60a7559d3f46c9d53f1ca875fd499a1e35e) quincy (stable)”} 1.0
10. ceph_mon_metadata:
MON Metadata. Metric type untyped.
CephMonDownQuorumAtRisk, and CephMonDownQuorumAtRisk
sample
ceph_mon_metadata{ceph_daemon=“mon.juju-080297-zaza-5e7b19357667-9”,hostname=“juju-080297-zaza-5e7b19357667-9”,public_addr=“10.5.1.21”,rank=“0”,ceph_version=“ceph version 17.2.0 (43e2e60a7559d3f46c9d53f1ca875fd499a1e35e) quincy (stable)”} 1.0
11. ceph_health_status:
Cluster health status. Metric type untyped.
CephHealthError, and CephHealthError
sample
ceph_health_status 0.0
12. ceph_pg_clean:
PG clean per pool. Metric type gauge.
sample
ceph_pg_clean{pool_id=“1”} 128.0
13. ceph_mon_quorum_status:
Monitors in quorum. Metric type gauge.
sample
ceph_mon_quorum_status{ceph_daemon=“mon.juju-080297-zaza-5e7b19357667-9”} 1.0
14. ceph_data_sync_from_zone_fetch_bytes_sum
Number of object bytes replicated Total. Metric type counter.
sample
ceph_data_sync_from_zone_fetch_bytes_sum{instance_id=“7524”,source_zone=“foo_sec”} 1500.0
15. ceph_data_sync_from_zone_fetch_bytes_count
Number of object bytes replicated Count. Metric type counter.
sample
ceph_data_sync_from_zone_fetch_bytes_count{instance_id=“7524”,source_zone=“foo_sec”} 10.0
16. ceph_data_sync_from_zone_fetch_errors
Number of object replication errors. Metric type counter.
sample
ceph_data_sync_from_zone_fetch_errors{instance_id=“7524”,source_zone=“foo_sec”} 2.0
17. ceph_data_sync_from_zone_fetch_not_modified
Number of objects already replicated. Metric type counter.
sample
ceph_data_sync_from_zone_fetch_not_modified{instance_id=“7524”,source_zone=“foo_sec”} 0.0
18. ceph_data_sync_from_zone_poll_errors
Number of replication log request errors. Metric type counter.
sample
ceph_data_sync_from_zone_poll_errors{instance_id=“7524”,source_zone=“foo_sec”} 2.0
19. ceph_data_sync_from_zone_poll_latency_sum
Average latency of replication log requests Total. Metric type counter.
sample
ceph_data_sync_from_zone_poll_latency_sum{instance_id=“7524”,source_zone=“foo_sec”} 18212.350834507
20. ceph_data_sync_from_zone_poll_latency_count
Average latency of replication log requests Count. Metric type counter.
sample
ceph_data_sync_from_zone_poll_latency_count{instance_id=“7524”,source_zone=“foo_sec”} 1685428.0
Section 2: Alerts
Ceph has a good number of alert rules configured by default for monitoring a general set of operational events; OSDs reaching near their Full Capacity, Daemon Crashes, and Device Failures to name a few. For a detailed description of individual alerts refer below:
1. CephMonDownQuorumAtRisk (mon)
Monitor quorum is at risk
Description
Quorum requires a majority of monitors (x) to be active. Without quorum the cluster will become inoperable, affecting all services and connected clients.
2. CephMonDiskspaceCritical (mon)
Filesystem space on at least one monitor is critically low
Description
The free space available to a monitor’s store is critically low. You should increase the space available to the monitor(s). The default directory is /var/lib/ceph/mon-/data/store.db on traditional deployments, and /var/lib/rook/mon-/data/store.db on the mon pod’s worker node for Rook. Look for old, rotated versions of .log and MANIFEST. Do NOT touch any *.sst files. Also check any other directories under /var/lib/rook and other directories on the same filesystem, often /var/log and /var/tmp are culprits.
3. CephMonDiskspaceLow (mon)
Drive space on at least one monitor is approaching full
Description
The space available to a monitor’s store is approaching full (>70% is the default). You should increase the space available to the monitor(s). The default directory is /var/lib/ceph/mon-/data/store.db on traditional deployments, and /var/lib/rook/mon-/data/store.db on the mon pod’s worker node for Rook. Look for old, rotated versions of .log and MANIFEST. Do NOT touch any *.sst files. Also check any other directories under /var/lib/rook and other directories on the same filesystem, often /var/log and /var/tmp are culprits.
4. CephMonClockSkew (mon)
Clock skew detected among monitors
Description
Ceph monitors rely on closely synchronized time to maintain quorum and cluster consistency. This event indicates that the time on at least one mon has drifted too far from the lead mon. Review cluster status with ceph -s. This will show which monitors are affected. Check the time sync status on each monitor host with ‘ceph time-sync-status’ and the state and peers of your ntpd or chrony daemon.
5. CephOSDHostDown (osd)
An OSD host is offline
Description
Describes the list of OSDs marked offline.
6. CephOSDDown (osd)
An OSD has been marked down
Description
OSD down for over 5mins. Describes the list of OSDs marked down.
7. CephOSDNearFull (osd)
OSD(s) running low on free space (NEARFULL)
Description
One or more OSDs have reached the NEARFULL threshold. Use ‘ceph health detail’ and ‘ceph osd df’ to identify the problem. To resolve, add capacity to the affected OSD’s failure domain, restore down/out OSDs, or delete unwanted data.
8. CephOSDFull (osd)
OSD full, writes blocked
Description
An OSD has reached the FULL threshold. Writes to pools that share the affected OSD will be blocked. Use ‘ceph health detail’ and ‘ceph osd df’ to identify the problem. To resolve, add capacity to the affected OSD’s failure domain, restore down/out OSDs, or delete unwanted data.
9. CephOSDBackfillFull (osd)
OSD(s) too full for backfill operations
Description
An OSD has reached the BACKFILL FULL threshold. This will prevent rebalance operations from completing. Use ‘ceph health detail’ and ‘ceph osd df’ to identify the problem. To resolve, add capacity to the affected OSD’s failure domain, restore down/out OSDs, or delete unwanted data.
10. CephOSDTooManyRepairs (osd)
OSD reports a high number of read errors
Description
Reads from an OSD have used a secondary PG to return data to the client, indicating a potential failing drive.
11. CephOSDTimeoutsPublicNetwork (osd)
Network issues delaying OSD heartbeats (public network)
Description
OSD heartbeats on the cluster’s ‘public’ network (frontend) are running slow. Investigate the network for latency or loss issues. Use ‘ceph health detail’ to show the affected OSDs.
12. CephOSDTimeoutsClusterNetwork (osd)
Network issues delaying OSD heartbeats (cluster network)
Description
OSD heartbeats on the cluster’s ‘cluster’ network (backend) are slow. Investigate the network for latency issues on this subnet. Use ‘ceph health detail’ to show the affected OSDs.
13. CephOSDInternalDiskSizeMismatch (osd)
OSD size inconsistency error
Description
One or more OSDs have an internal inconsistency between metadata and the size of the device. This could lead to the OSD(s) crashing in future. You should redeploy the affected OSDs.
14. CephDeviceFailurePredicted (osd)
Device(s) predicted to fail soon
Description
The device health module has determined that one or more devices will fail soon. To review device status use ‘ceph device ls’. To show a specific device use 'ceph device info '. Mark the OSD out so that data may migrate to other OSDs. Once the OSD has drained, destroy the OSD, replace the device, and redeploy the OSD.
15. CephDeviceFailurePredictionTooHigh (osd)
Too many devices are predicted to fail, unable to resolve
Description
The device health module has determined that devices predicted to fail can not be remediated automatically, since too many OSDs would be removed from the cluster to ensure performance and availabililty. Prevent data integrity issues by adding new OSDs so that data may be relocated.
16. CephDeviceFailureRelocationIncomplete (osd)
Device failure is predicted, but unable to relocate data
Description
The device health module has determined that one or more devices will fail soon, but the normal process of relocating the data on the device to other OSDs in the cluster is blocked. Ensure that the cluster has available free space. It may be necessary to add capacity to the cluster to allow data from the failing device to successfully migrate, or to enable the balancer.
17. CephOSDReadErrors (osd)
Device read errors detected
Description
An OSD has encountered read errors, but the OSD has recovered by retrying the reads. This may indicate an issue with hardware or the kernel.
18. CephFilesystemDamaged (mds)
CephFS filesystem is damaged.
Description
Filesystem metadata has been corrupted. Data may be inaccessible. Analyze metrics from the MDS daemon admin socket, or escalate to support.
19. CephFilesystemOffline (mds)
CephFS filesystem is offline
Description
All MDS ranks are unavailable. The MDS daemons managing metadata are down, rendering the filesystem offline.
20. CephFilesystemDegraded (mds)
CephFS filesystem is degraded
Description
One or more metadata daemons (MDS ranks) are failed or in a damaged state. At best the filesystem is partially available, at worst the filesystem is completely unusable.
21. CephFilesystemMDSRanksLow (mds)
Ceph MDS daemon count is lower than configured
Description
The filesystem’s ‘max_mds’ setting defines the number of MDS ranks in the filesystem. The current number of active MDS daemons is less than this value.
22. CephFilesystemInsufficientStandby (mds)
Ceph filesystem standby daemons too few
Description
The minimum number of standby daemons required by standby_count_wanted is less than the current number of standby daemons. Adjust the standby count or increase the number of MDS daemons.
23. CephFilesystemFailureNoStandby (mds)
MDS daemon failed, no further standby available
Description
An MDS daemon has failed, leaving only one active rank and no available standby. Investigate the cause of the failure or add a standby MDS.
24. CephFilesystemReadOnly (mds)
CephFS filesystem in read only mode due to write error(s)
Description
The filesystem has switched to READ ONLY due to an unexpected error when writing to the metadata pool. Either analyze the output from the MDS daemon admin socket, or escalate to support.
25. CephMgrModuleCrash (mgr)
A manager module has recently crashed
Description
One or more mgr modules have crashed and have yet to be acknowledged by an administrator. A crashed module may impact functionality within the cluster. Use the ‘ceph crash’ command to determine which module has failed, and archive it to acknowledge the failure.
26. CephPGsDamaged (pgs)
Placement group damaged, manual intervention needed
Description
During data consistency checks (scrub), at least one PG has been flagged as being damaged or inconsistent. Check to see which PG is affected, and attempt a manual repair if necessary. To list problematic placement groups, use 'rados list-inconsistent-pg '. To repair PGs use the ‘ceph pg repair <pg_num>’ command.
27. CephPGRecoveryAtRisk (pgs)
OSDs are too full for recovery
Description
Data redundancy is at risk since one or more OSDs are at or above the ‘full’ threshold. Add more capacity to the cluster, restore down/out OSDs, or delete unwanted data.
28. CephPGUnavilableBlockingIO (pgs)
PG is unavailable, blocking I/O
Description
Data availability is reduced, impacting the cluster’s ability to service I/O. One or more placement groups (PGs) are in a state that blocks I/O.
29. CephPGBackfillAtRisk (pgs)
Backfill operations are blocked due to lack of free space
Description
Data redundancy may be at risk due to lack of free space within the cluster. One or more OSDs have reached the ‘backfillfull’ threshold. Add more capacity, or delete unwanted data.
30. CephPGNotScrubbed (pgs)
Placement group(s) have not been scrubbed
Description
One or more PGs have not been scrubbed recently. Scrubs check metadata integrity, protecting against bit-rot. They check that metadata is consistent across data replicas. When PGs miss their scrub interval, it may indicate that the scrub window is too small, or PGs were not in a ‘clean’ state during the scrub window. You can manually initiate a scrub with: ceph pg scrub
31. CephPGsHighPerOSD (pgs)
Placement groups per OSD is too high
Description
The number of placement groups per OSD is too high (exceeds the mon_max_pg_per_osd setting). Check that the pg_autoscaler has not been disabled for any pools with ‘ceph osd pool autoscale-status’, and that the profile selected is appropriate. You may also adjust the target_size_ratio of a pool to guide the autoscaler based on the expected relative size of the pool (‘ceph osd pool set cephfs.cephfs.meta target_size_ratio .1’) or set the pg_autoscaler mode to ‘warn’ and adjust pg_num appropriately for one or more pools.
32. CephPGNotDeepScrubbed (pgs)
Placement group(s) have not been deep scrubbed
Description
One or more PGs have not been deep scrubbed recently. Deep scrubs protect against bit-rot. They compare data replicas to ensure consistency. When PGs miss their deep scrub interval, it may indicate that the window is too small or PGs were not in a ‘clean’ state during the deep-scrub window.
33. CephPoolBackfillFull (pools)
Free space in a pool is too low for recovery/backfill
Description
A pool is approaching the near full threshold, which will prevent recovery/backfill operations from completing. Consider adding more capacity.
34. CephPoolFull (pools)
Pool is full - writes are blocked
Description
A pool has reached its MAX quota, or OSDs supporting the pool have reached the FULL threshold. Until this is resolved, writes to the pool will be blocked. Pool Breakdown (top 5) - at % Increase the pool’s quota, or add capacity to the cluster first then increase the pool’s quota (e.g. ceph osd pool set quota <pool_name> max_bytes )
35. CephPoolNearFull (pools)
One or more Ceph pools are nearly full
Description
A pool has exceeded the warning (percent full) threshold, or OSDs supporting the pool have reached the NEARFULL threshold. Writes may continue, but you are at risk of the pool going read-only if more capacity isn’t made available. Determine the affected pool with ‘ceph df detail’, looking at QUOTA BYTES and STORED. Increase the pool’s quota, or add capacity to the cluster first then increase the pool’s quota (e.g. ceph osd pool set quota <pool_name> max_bytes ). Also ensure that the balancer is active.
36. CephadmUpgradeFailed (cephadm)
Ceph version upgrade has failed
Description
The cephadm cluster upgrade process has failed. The cluster remains in an undetermined state. Please review the cephadm logs, to understand the nature of the issue
37. CephadmDaemonFailed (cephadm)
A ceph daemon manged by cephadm is down
Description
A daemon managed by cephadm is no longer active. Determine, which daemon is down with ‘ceph health detail’. you may start daemons with the ‘ceph orch daemon start <daemon_id>’
38. CephadmPaused (cephadm)
Orchestration tasks via cephadm are PAUSED
Description
Cluster management has been paused manually. This will prevent the orchestrator from service management and reconciliation. If this is not intentional, resume cephadm operations with ‘ceph orch resume’
39. CephObjectMissing (rados)
Object(s) marked UNFOUND
Description
The latest version of a RADOS object can not be found, even though all OSDs are up. I/O requests for this object from clients will block (hang). Resolving this issue may require the object to be rolled back to a prior version manually, and manually verified.
40. CephDaemonCrash (generic)
One or more Ceph daemons have crashed, and are pending acknowledgement
Description
One or more daemons have crashed recently, and need to be acknowledged. This notification ensures that software crashes do not go unseen. To acknowledge a crash, use the 'ceph crash archive ’ command.
41. CephPGsInactive (pgs)
One or more placement groups are inactive
Description
PGs have been inactive for more than 5 minutes in pool . Inactive placement groups are not able to serve read/write requests.
42. CephPGImbalance (osd)
PGs are not balanced across OSDs
Description
OSD on deviates by more than 30% from average PG count.
43. CephOSDDownHigh (osd)
More than 10% of OSDs are down
Description
% or of OSDs are down (>= 10%). The following OSDs are down: - on
44. CephOSDFlapping (osd)
Network issues are causing OSDs to flap (mark each other down)
Description
OSD on was marked down and back up times once a minute for 5 minutes. This may indicate a network issue (latency, packet loss, MTU mismatch) on the cluster network, or the public network if no cluster network is deployed. Check the network stats on the listed host(s).
45. CephPGsUnclean (pgs)
One or more placement groups are marked unclean
Description
PGs have been unclean for more than 15 minutes in pool . Unclean PGs have not recovered from a previous failure.
46. CephSlowOps (healthchecks)
OSD operations are slow to complete
Description
OSD requests are taking too long to process (osd_op_complaint_time exceeded)
47. CephPoolGrowthWarning (pools)
Pool growth rate may soon exceed capacity
Description
Pool ‘’ will be full in less than 5 days assuming the average fill-up rate of the past 48 hours.
48. CephMonDown (mon)
One or more monitors down
Description
You have monitor down. Quorum is still intact, but the loss of an additional monitor will make your cluster inoperable. The following monitors are down: - on
49. CephHealthError (cluster health)
Ceph is in the ERROR state
Description
The cluster state has been HEALTH_ERROR for more than 5 minutes. Please check ‘ceph health detail’ for more information.
50. CephHealthWarning (cluster health)
Ceph is in the WARNING state
Description
The cluster state has been HEALTH_WARN for more than 15 minutes. Please check ‘ceph health detail’ for more information.
51. CephRGWMultisitePollError
Unsuccessful Replication Log Request Errors Threshold Exceeded
Description
Unsuccessful replication log request errors threshold has been exceeded. The threshold is defined as 2 errors per 15min
52. CephRGWMultisitePollErrorCritical
Critical: Unsuccessful Replication Log Request Errors Threshold Exceeded
Description
Critical: Unsuccessful replication log request errors threshold has been exceeded. The threshold is defined as 50 errors per 15min
53. CephRGWMultisiteFetchError
Unsuccessful Object Replications from Source Zone Threshold Exceeded
Description
Unsuccessful Object Replications from source zone threshold has been exceeded. The threshold is defined as 2 errors per 15min
54. CephRGWMultisiteFetchErrorCritical
Critical: Unsuccessful Object Replications from Source Zone Threshold Exceeded
Description
Critical: Unsuccessful Object Replications from source zone threshold has been exceeded. The threshold is defined as 50 errors per 15min
55. CephRGWMultisitePollLatency
Poll Request Latency Threshold Exceeded
Description
Latency for poll request threshold exceeded. The threshold is defined as 600s latency per 15min
