Overview
The ceph-iscsi charm deploys the Ceph iSCSI gateway service. The charm is intended to be used in conjunction with the ceph-osd and ceph-mon charms.
NOTE: This charm is deprecated. No new features will be introduced.
Important: This documentation supports version 3.x of the Juju client.
See the OpenStack Charm
guide if you are using the 2.9.x client.
Usage
Configuration
See file config.yaml for the full list of options, along with their descriptions and default values.
Ceph BlueStore compression
This charm supports [BlueStore inline compression][ceph-bluestore-compression] for its associated Ceph storage pool(s). The feature is enabled by assigning a compression mode via the bluestore-compression-mode configuration option. The default behaviour is to disable compression.
The efficiency of compression depends heavily on what type of data is stored in the pool and the charm provides a set of configuration options to fine tune the compression behaviour.
Note: BlueStore compression is supported starting with Ceph Mimic.
Deployment
We are assuming a pre-existing Ceph cluster.
To provide multiple data paths to clients deploy exactly two ceph-iscsi units:
juju deploy -n 2 ceph-iscsi
Then add a relation to the ceph-mon application:
juju integrate ceph-iscsi:ceph-client ceph-mon:client
Notes:
- Deploying four ceph-iscsi units is theoretically possible but it is not an officially supported configuration.
- The ceph-iscsi application cannot be containerised.
- Co-locating ceph-iscsi with another application is only supported with ceph-osd, although doing so with other applications may still work.
Actions
This section covers Juju actions supported by the charm. Actions allow specific operations to be performed on a per-unit basis. To display action descriptions run juju actions ceph-iscsi. If the charm is not deployed then see file actions.yaml.
add-trusted-ipcreate-targetpauseresumesecurity-checklist
iSCSI target management
Create an iSCSI target
An iSCSI target can be created easily with the charm’s create-target action:
juju run --wait ceph-iscsi/0 create-target \
client-initiatorname=iqn.1993-08.org.debian:01:aaa2299be916 \
client-username=myiscsiusername \
client-password=myiscsipassword \
image-size=5G \
image-name=small \
pool-name=images
In the above, all option values are generally user-defined with the exception of the initiator name (client-initiatorname). An iSCSI initiator is essentially an iSCSI client and so its name is client-dependent. Some initiators may impose policy on credentials (client-username and client-password).
Important: The underlying machines for the ceph-iscsi units must have internal name resolution working (i.e. the machines must be able to resolve each other’s hostnames).
The gwcli utility
The management of targets, beyond the target-creation action described above, can be accomplished via the gwcli utility. This CLI tool has its own shell, and is available from any ceph-iscsi unit:
juju ssh ceph-iscsi/1
sudo gwcli
/> help
VMware integration
Ceph can be used to back iSCSI targets for VMware initiators. This is documented under VMware integration in the Charmed Ceph documentation.
Bugs
Please report bugs on Launchpad.
For general charm questions refer to the OpenStack Charm Guide.
Navigation
| Level | Path | Navlink |
| 1 | Home |
