Overview
The ceph-dashboard charm deploys the Ceph Dashboard, a built-in web-based Ceph management and monitoring application. It works in conjunction with the openstack-loadbalancer charm, which in turn utilises the hacluster charm.
Important: This documentation supports version 3.x of the Juju client.
See the OpenStack Charm
guide if you are using the 2.9.x client.
Usage
Configuration
This section covers common and/or important configuration options. See file config.yaml for the full list of options, along with their descriptions and default values. See the Juju documentation for details on configuring applications.
grafana-api-url
Sets the URL of the Grafana API when using embedded graphs. See Embedded Grafana dashboards.
public-hostname
Sets the hostname or address of the public endpoint used to access the dashboard.
enable-password-policy
Sets whether certain password restrictions are enforced when a user is created or changes their password.
password-*
There are a number of password-* options which impose constraints on which passwords can be used. These options are ignored unless enable-password-policy is set to ‘True’.
Deployment
We are assuming a pre-existing Ceph cluster (see here on how to set up a cluster).
Deploy ceph-dashboard as a subordinate to the ceph-mon charm:
juju deploy ceph-dashboard
juju integrate ceph-dashboard:dashboard ceph-mon:dashboard
TLS is a requirement for this charm. Enable it by adding a relation to the vault application:
juju integrate ceph-dashboard:certificates vault:certificates
See Managing TLS certificates in the OpenStack Charms Deployment Guide for more information on TLS.
Note: This charm also supports TLS configuration via charm options
ssl_cert,ssl_key, andssl_ca.
Load balancer
The dashboard is accessed via a load balancer using VIPs and implemented via the openstack-loadbalancer and hacluster charms:
juju deploy -n 3 --config vip=10.5.20.200 openstack-loadbalancer
juju deploy hacluster openstack-loadbalancer-hacluster
juju integrate openstack-loadbalancer:ha openstack-loadbalancer-hacluster:ha
Now add a relation between the openstack-loadbalancer and ceph-dashboard applications:
juju integrate ceph-dashboard:loadbalancer openstack-loadbalancer:loadbalancer
Dashboard user
Credentials are needed to log in to the dashboard. Set these up by applying an action to any ceph-dashboard unit. For example, to create an administrator user called ‘admin’:
juju run ceph-dashboard/0 add-user username=admin role=administrator
The command’s output will include a generated password.
The dashboard can then be accessed on the configured VIP and on port 8443:
To embed Grafana dashboards within the Ceph dashboard some additional relations are required (Grafana, Telegraf, and Prometheus are assumed to be pre-existing):
juju integrate ceph-dashboard:grafana-dashboard grafana:dashboards
juju integrate ceph-dashboard:prometheus prometheus:website
juju integrate ceph-mon:prometheus prometheus:target
juju integrate ceph-osd:juju-info telegraf:juju-info
juju integrate ceph-mon:juju-info telegraf:juju-info
Grafana, Telegraf, and Prometheus should be related in the standard way:
juju integrate grafana:grafana-source prometheus:grafana-source
juju integrate telegraf:prometheus-client prometheus:target
juju integrate telegraf:dashboards grafana:dashboards
When Grafana is integrated with the Ceph Dashboard it requires TLS, so add a relation to Vault (the grafana charm also supports TLS configuration via ssl_* charm options):
juju integrate grafana:certificates vault:certificates
Important: Ceph Dashboard will (silently) fail to display Grafana output if the client browser cannot validate the Grafana server’s TLS certificate. Either ensure the signing CA certificate is known to the browser or, if in a testing environment, contact the Grafana dashboard directly and have the browser accept the unverified certificate.
Grafana should be configured with the following charm options:
juju config grafana anonymous=True
juju config grafana allow_embedding=True
The grafana charm also requires the vonage-status-panel and grafana-piechart-panel plugins. The install_plugins configuration option should be set to include URLs from which these plugins can be downloaded. They are currently available from https://storage.googleapis.com/plugins-community. For example:
juju config grafana install_plugins="https://storage.googleapis.com/plugins-community/vonage-status-panel/release/1.0.11/vonage-status-panel-1.0.11.zip,https://storage.googleapis.com/plugins-community/grafana-piechart-panel/release/1.6.2/grafana-piechart-panel-1.6.2.zip"
Telegraf should be configured with the following charm option:
juju config telegraf hostname="{host}"
Note: The above command is to be invoked verbatim; no substitution is required.
Currently the dashboard does not autodetect the API endpoint of the Grafana service. It needs to be provided via a configuration option:
juju config ceph-dashboard grafana-api-url="https://<IP of grafana unit>:3000"
Prometheus alerting
To enable alerting for an existing Prometheus service add the following relations:
juju integrate ceph-dashboard:alertmanager-service prometheus-alertmanager:alertmanager-service
juju integrate prometheus:alertmanager-service prometheus-alertmanager:alertmanager-service
Ceph Object storage
To enable Object storage management of an existing Ceph RADOS Gateway service add the following relation:
juju integrate ceph-dashboard:radosgw-dashboard ceph-radosgw:radosgw-user
Note: For Ceph versions older than Pacific the dashboard can only be related to a single ceph-radosgw application.
iSCSI targets
To display information for an existing iSCSI gateway/target service add the following relation:
juju integrate ceph-iscsi:admin-access ceph-dashboard:iscsi-dashboard
Actions
This section lists Juju actions supported by the charm. Actions allow specific operations to be performed on a per-unit basis. To display action descriptions run juju actions --schema ceph-dashboard. If the charm is not deployed then see file actions.yaml.
add-userdelete-user
Documentation
The OpenStack Charms project maintains two documentation guides:
- OpenStack Charm Guide: for project information, including development and support notes
- OpenStack Charms Deployment Guide: for charm usage information
Bugs
Please report bugs on Launchpad.
Navigation
| Level | Path | Navlink |
| 1 | Home |
