Hi, we used a custom cdk-addons snap because we needed to change some settings for the metrics module to avoid OOMKill :
Here is what we changed :
- “base_metrics_server_cpu”: “40m”,
- “base_metrics_server_memory”: “40Mi”,
- “metrics_server_memory_per_node”: “4”,
+ “base_metrics_server_cpu”: “200m”,
+ “base_metrics_server_memory”: “256Mi”,
+ “metrics_server_memory_per_node”: “16”,
This is what I get when listing snaps :
ubuntu@juju-806d1a-52-lxd-1:~$ snap list
Name Version Rev Tracking Publisher Notes
cdk-addons 1.16.15 x3 - - -
core 16-2.49 10859 latest/stable canonical✓ core
core18 20210128 1988 latest/stable canonical✓ base
kube-apiserver 1.16.15 1789 1.16/stable canonical✓ in-cohort
kube-controller-manager 1.16.15 1685 1.16/stable canonical✓ in-cohort
kube-proxy 1.16.15 1673 1.16/stable canonical✓ classic
kube-scheduler 1.16.15 1639 1.16/stable canonical✓ in-cohort
kubectl 1.16.15 1639 1.16/stable canonical✓ classic,in-cohort
When trying to upgrade the kubernetes-master charm to 808, we get :
File “/var/lib/juju/agents/unit-kubernetes-master-15/.venv/lib/python3.6/site-packages/charms/reactive/bus.py”, line 359, in _invoke
handler.invoke()
File “/var/lib/juju/agents/unit-kubernetes-master-15/.venv/lib/python3.6/site-packages/charms/reactive/bus.py”, line 181, in invoke
self._action(*args)
File “/var/lib/juju/agents/unit-kubernetes-master-15/charm/reactive/kubernetes_master.py”, line 434, in join_or_update_cohorts
snap.join_cohort_snapshot(snapname, cohort_key)
File “lib/charms/layer/snap.py”, line 425, in join_cohort_snapshot
‘–cohort’, cohort_key])
File “/usr/lib/python3.6/subprocess.py”, line 356, in check_output
**kwargs).stdout
File “/usr/lib/python3.6/subprocess.py”, line 438, in run
output=stdout, stderr=stderr)
subprocess.CalledProcessError: Command ‘[‘snap’, ‘refresh’, ‘cdk-addons’, ‘–cohort’, ‘MSBlZUVJQ25EaUIzdGo5NHBLUU0xQnd0RWN2VmdIZTk1biAxNjEzNDU0NzQ4IDhmYmI0NzJmMmZhZjBkNmIyYWY2MzM4Yjk3OWJiZWY1NzRhMmJlODliMjg3ZWI2NWMyODNjYTY4ODdkMDk5Y2Y=’]’ returned non-zero exit status 1.
unit-kubernetes-master-15: 15:36:09 WARNING unit.kubernetes-master/15.upgrade-charm Traceback (most recent call last):
unit-kubernetes-master-15: 15:36:09 WARNING unit.kubernetes-master/15.upgrade-charm File “/var/lib/juju/agents/unit-kubernetes-master-15/charm/hooks/upgrade-charm”, line 22, in
unit-kubernetes-master-15: 15:36:09 WARNING unit.kubernetes-master/15.upgrade-charm main()
unit-kubernetes-master-15: 15:36:09 WARNING unit.kubernetes-master/15.upgrade-charm File “/var/lib/juju/agents/unit-kubernetes-master-15/.venv/lib/python3.6/site-packages/charms/reactive/init.py”, line 74, in main
unit-kubernetes-master-15: 15:36:09 WARNING unit.kubernetes-master/15.upgrade-charm bus.dispatch(restricted=restricted_mode)
unit-kubernetes-master-15: 15:36:09 WARNING unit.kubernetes-master/15.upgrade-charm File “/var/lib/juju/agents/unit-kubernetes-master-15/.venv/lib/python3.6/site-packages/charms/reactive/bus.py”, line 390, in dispatch
unit-kubernetes-master-15: 15:36:09 WARNING unit.kubernetes-master/15.upgrade-charm _invoke(other_handlers)
unit-kubernetes-master-15: 15:36:09 WARNING unit.kubernetes-master/15.upgrade-charm File “/var/lib/juju/agents/unit-kubernetes-master-15/.venv/lib/python3.6/site-packages/charms/reactive/bus.py”, line 359, in _invoke
unit-kubernetes-master-15: 15:36:09 WARNING unit.kubernetes-master/15.upgrade-charm handler.invoke()
unit-kubernetes-master-15: 15:36:09 WARNING unit.kubernetes-master/15.upgrade-charm File “/var/lib/juju/agents/unit-kubernetes-master-15/.venv/lib/python3.6/site-packages/charms/reactive/bus.py”, line 181, in invoke
unit-kubernetes-master-15: 15:36:09 WARNING unit.kubernetes-master/15.upgrade-charm self._action(*args)
unit-kubernetes-master-15: 15:36:09 WARNING unit.kubernetes-master/15.upgrade-charm File “/var/lib/juju/agents/unit-kubernetes-master-15/charm/reactive/kubernetes_master.py”, line 434, in join_or_update_cohorts
unit-kubernetes-master-15: 15:36:09 WARNING unit.kubernetes-master/15.upgrade-charm snap.join_cohort_snapshot(snapname, cohort_key)
unit-kubernetes-master-15: 15:36:09 WARNING unit.kubernetes-master/15.upgrade-charm File “lib/charms/layer/snap.py”, line 425, in join_cohort_snapshot
unit-kubernetes-master-15: 15:36:09 WARNING unit.kubernetes-master/15.upgrade-charm ‘–cohort’, cohort_key])
unit-kubernetes-master-15: 15:36:09 WARNING unit.kubernetes-master/15.upgrade-charm File “/usr/lib/python3.6/subprocess.py”, line 356, in check_output
unit-kubernetes-master-15: 15:36:09 WARNING unit.kubernetes-master/15.upgrade-charm **kwargs).stdout
unit-kubernetes-master-15: 15:36:09 WARNING unit.kubernetes-master/15.upgrade-charm File “/usr/lib/python3.6/subprocess.py”, line 438, in run
unit-kubernetes-master-15: 15:36:09 WARNING unit.kubernetes-master/15.upgrade-charm output=stdout, stderr=stderr)
unit-kubernetes-master-15: 15:36:09 WARNING unit.kubernetes-master/15.upgrade-charm subprocess.CalledProcessError: Command ‘[‘snap’, ‘refresh’, ‘cdk-addons’, ‘–cohort’, ‘MSBlZUVJQ25EaUIzdGo5NHBLUU0xQnd0RWN2VmdIZTk1biAxNjEzNDU0NzQ4IDhmYmI0NzJmMmZhZjBkNmIyYWY2MzM4Yjk3OWJiZWY1NzRhMmJlODliMjg3ZWI2NWMyODNjYTY4ODdkMDk5Y2Y=’]’ returned non-zero exit status 1.
unit-kubernetes-master-15: 15:36:09 ERROR juju.worker.uniter.operation hook “upgrade-charm” (via explicit, bespoke hook script) failed: exit status 1
unit-kubernetes-master-15: 15:36:09 DEBUG juju.machinelock machine lock released for kubernetes-master/15 uniter (run upgrade-charm hook)
unit-kubernetes-master-15: 15:36:09 DEBUG juju.worker.uniter.operation lock released for kubernetes-master/15
unit-kubernetes-master-15: 15:36:09 DEBUG juju.worker.uniter.operation running operation run commands for kubernetes-master/15
unit-kubernetes-master-15: 15:36:09 DEBUG juju.machinelock acquire machine lock for kubernetes-master/15 uniter (run commands)
unit-kubernetes-master-15: 15:36:09 DEBUG juju.machinelock machine lock acquired for kubernetes-master/15 uniter (run commands)
Running the command manually gives this :
root@juju-806d1a-52-lxd-1:~# snap refresh cdk-addons --cohort MSBlZUVJQ25EaUIzdGo5NHBLUU0xQnd0RWN2VmdIZTk1biAxNjEzNDU0NzQ4IDhmYmI0NzJmMmZhZjBkNmIyYWY2MzM4Yjk3OWJiZWY1NzRhMmJlODliMjg3ZWI2NWMyODNjYTY4ODdkMDk5Y2Y=
error: local snap “cdk-addons” is unknown to the store, use --amend to proceed anyway
So, what’s the solution here ?
Is there a way to modify those settings while keeping the original charm ?
Can we somehow bypass this one, since we manage it internally ?
Patrick
