Using the catalogue-k8s charm is extremely easy, and it gives you a convenient way to access all your charms.
First, deploy catalogue-k8s and some charms that support the catalogue relation:
∮ juju deploy catalogue-k8s catalogue
# Deploy some charms that have a 'catalogue' integration (--trust needed for resource patch)
∮ juju deploy prometheus-k8s prometheus --trust
∮ juju deploy grafana-k8s grafana --trust
Then, relate them:
∮ juju relate catalogue:catalogue prometheus
∮ juju relate catalogue:catalogue grafana
If you now open the catalogue website, you’ll see the apps you added in the UI!
∮ juju run catalogue/leader get-url
