Usage
Install
To install the charm, run:
# Create dedicated namespace on k8s cluster
juju add-model capsule-system
# Deploy capsule along with the charm operator
juju deploy --trust charm-k8s-capsule
Configure
To configure the charm, run:
# Example: juju config capsule-k8s key=value
juju config capsule-k8s force-tenant-prefix=true
juju config capsule-k8s user-groups=capsule.clastix.io,system:serviceaccounts:default
In case you have multiple CapsuleConfiguration instances, you can modify a specific one by using the capsule-configuration-name parameter with the name of the resource you want to modify:
juju config capsule-k8s capsule-configuration-name=capsule-configuration-2 force-tenant-prefix=true
The configurable parameters are:
| name | description | type | default | references |
user-groups |
Comma-separated list of user groups (example: oil.capsule.io,gas.capsule.io). |
string | capsule.clastix.io |
force-tenant-prefix |
Force to have a tenant prefix. | boolean | false |
protected-namespace-regex |
Disallows creation of namespaces matching the passed regexp. | string | "" |
