Was able to fire up a controller but when trying to fire up an app I get this error.
172.31.1.11 has a self-signed certificate. Is there a way to exclude SSL verification?
Juju does support adding a CA certificate to the cloud metadata it stores about each cloud that it can bootstrap to. All locally defined clouds are stored in ~/.local/share/juju/clouds.yaml
If you look there, there should be an entry like
clouds:
mycloud:
type: vsphere
auth-types: [userpass]
endpoint: https://xxxxxxx
ca-certificates:
-----BEGIN CERTIFICATE-----
MIIE6DCCAtCgAwIBAgIQGncDt7wdwyH2LTA1ai5z3jANBgkqhkiG9w0BAQsFADAN
dO07QhGm3GjU2p6r
-----END CERTIFICATE-----
Using add-cloud
I think you are prompted for this certificate, but if not, you could paste it into the above yaml file and bootstrap again and see if that helps.
