Hello
I have a charm where I have storage configured but I would like to remove it from the charm.
When I try to refresh a deployed charm I get:
ERROR cannot upgrade application “geth” to charm “local:jammy/geth-3”: required storage “data” removed
So I tried to detach it with juju detach-storage data/0 --force and get:
failed to detach data/0: cannot destroy storage attachment data/0:geth/0: cannot detach, storage is singular.
Can someone explain how to detach this kind of storage?
Step by step
- Deploy charm with storage configured.
- Remove the storage config from the charm
- Refresh with new charm where storage is removed.
juju refresh geth --path=./geth_ubuntu-22.04-amd64.charm
Added local charm "geth", revision 3, to the model ERROR cannot upgrade application "geth" to charm "local:jammy/geth-3": required storage "data" removed
- Try to remove or detach storage with or without --force results in
