Hi there,
I’m hitting an issue trying to add a model on the ‘localhost’ cloud (lxd) given that the controller lives on microk8s.
Given a fresh install:
$ snap list
juju 3.6.6 31166 3/stable canonical✓ -
lxd 5.21.3-c5ae129 33110 5.21/stable canonical✓ -
microk8s v1.31.7 7968 1.31-strict/stable canonical✓ -
Proceeding with the following setup goes fine:
$ juju clouds
localhost 1 localhost lxd 1 built-in LXD Container Hypervisor
microk8s 1 localhost k8s 1 built-in A Kubernetes Cluster
$ juju bootstrap microk8s k8s-ctrl
$ juju add-cloud -c k8s-ctrl localhost
$ juju clouds
Clouds available on the controller:
However once I try to add a model on ‘localhost’, I get an error:
$ juju add-model --controller k8s-ctrl lxd-model localhost --debug --show-log
18:28:22 INFO juju.cmd supercommand.go:56 running juju [3.6.6 48f295cccb79738cc30a3d280da011a027cd4d16 gc go1.24.2]
18:28:22 DEBUG juju.cmd supercommand.go:57 args: []string{"/snap/juju/31166/bin/juju", "add-model", "--controller", "k8s-ctrl", "lxd-model", "localhost", "--debug", "--show-log"}
18:28:22 INFO juju.juju api.go:90 connecting to API addresses: [10.152.183.120:17070]
18:28:22 INFO juju.kubernetes.klog klog.go:113 Use tokens from the TokenRequest API or manually created secret-based tokens instead of auto-generated secret-based tokens.%!(EXTRA []interface {}=[])
18:28:22 DEBUG juju.api apiclient.go:537 starting proxier for connection
18:28:22 DEBUG juju.api apiclient.go:541 tunnel proxy in use at localhost on port 41217
18:28:22 DEBUG juju.api apiclient.go:1080 successfully dialed "wss://localhost:41217/api"
18:28:22 INFO juju.api apiclient.go:601 connection established to "wss://localhost:41217/api"
18:28:22 INFO cmd authkeys.go:113 Adding contents of "/home/ubuntu/.local/share/juju/ssh/juju_id_rsa.pub" to authorized-keys
18:28:22 DEBUG juju.container.lxd connection.go:180 using LXD socket at path: "/var/snap/lxd/common/lxd/unix.socket"
18:28:22 DEBUG juju.api monitor.go:35 RPC connection died
ERROR failed to open environ: LXD socket not found; is LXD installed & running?
Please install LXD by running:
$ sudo snap install lxd
and then configure it with:
$ newgrp lxd
$ lxd init
18:28:22 DEBUG cmd supercommand.go:571 error stack:
$ newgrp lxd
$ lxd init
github.com/juju/juju/rpc.(*Conn).Call:178:
github.com/juju/juju/api.(*state).APICall:1182:
github.com/juju/juju/api/client/modelmanager.(*Client).CreateModel:78:
github.com/juju/juju/cmd/juju/controller.(*addModelCommand).Run:275:
Obviously LXD is installed and initialized. I can successfully juju bootstrap localhost tmp-ctrl and then add a model to make sure of that.
Furthermore, I can also successfully expose LXD on a local port, add-cloud it as a remote cloud with the IP to both the client & microk8s controller and proceed with adding a model and deploying stuff… So this really points toward an integration issue with the snap socket.
Any idea what going on and/or any suggestions as to how to get this setup working?
Thanks.
